Guest George89 Posted June 20, 2011 Share Posted June 20, 2011 My car won't produce more then 0.4 bar of boost and the 2nd turbo won't kick in, After over 3 weeks of trying to find the problem i found something that doesn't look right but i need to ask for your advice. On the 2nd turbo above it the actuator i think its a EGC. The EGC which is attached to the rod looks like its come out about a inch, e.g. the rod is quite rusty but towards the actuater it looks like brand new metal which has oil on it. Does that mean its stuck open? if you understand what i mean. Its not easy to explain Quote Link to comment Share on other sites More sharing options...
