dude Posted June 21, 2011 Share Posted June 21, 2011 searching for fb page Search for AFR Performance Tuning on pages and click like. Link to comment Share on other sites More sharing options...
j_jza80 Posted June 21, 2011 Share Posted June 21, 2011 (edited) Petrol and brake lines seem to do ok though They don't hang down the back of the car like that. One bad pothole would spell the end of that system IMO, especially on a Porsche that is known to squat on WOT. The biggest advantage I can see, other than for packaging, is the lack of a complicated (and usually expensive) turbo-exhaust manifold. Edited June 21, 2011 by j_jza80 (see edit history) Link to comment Share on other sites More sharing options...
dude Posted June 21, 2011 Share Posted June 21, 2011 They don't hang down the back of the car like that. One bad pothole would spell the end of that system IMO, especially on a Porsche that is known to squat on WOT. The biggest advantage I can see, other than for packaging, is the lack of a complicated (and usually expensive) turbo-exhaust manifold. Then you would make sure they are clipped up out of the way. Link to comment Share on other sites More sharing options...
J_Supra_07 Posted June 21, 2011 Share Posted June 21, 2011 The 911 looks dogs. Long pipes to a front engine on other hand humm, it'd look good but the sorter the pipes the better I'd say. Any ways u got till u bloww this one before u think of ur next crazy build ;-). Link to comment Share on other sites More sharing options...
dude Posted June 21, 2011 Share Posted June 21, 2011 I will bet that the diff in pipe length between a 2JZ and what im doing and the fact you dont need an IC will be negligable. Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 21, 2011 Author Share Posted June 21, 2011 thers alot of pipe on my na-t id say atleast 8 ft plus an itercooler. by the time you remove the cooler id say the total internal area will be pretty similar . iv;e been reading alot about area ratios ect since this thaught first enterd my mind and with small compensations hear and t6here i see no reason why this cant be a good way of doing things. and looking at the reults some of the holdens and vetts have had it looks to work well . Link to comment Share on other sites More sharing options...
