Thomas.B Posted June 19, 2011 Share Posted June 19, 2011 Hey, still believe I have a fuel issue after changing the Lambda. As far as I remember I shouldnt have to reset anything when changing it, right? Anything else that can be making it use this much fuel? (I am not driving like an arse all of the time) Quote Link to comment Share on other sites More sharing options...
Nic Posted June 19, 2011 Share Posted June 19, 2011 Did you fit a new genuine Toyota oxygen sensor? You could try resetting the ECU by disconnecting the battery. Quote Link to comment Share on other sites More sharing options...
imi Posted June 19, 2011 Share Posted June 19, 2011 Hey, still believe I have a fuel issue after changing the Lambda. As far as I remember I shouldnt have to reset anything when changing it, right? Anything else that can be making it use this much fuel? (I am not driving like an arse all of the time) whats your average fuel consumption? you should be seeing a combined mileage of around 18-22mpg with a TT Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted June 19, 2011 Author Share Posted June 19, 2011 I came 8mpg when driving steady at around 80mph. 120-130miles on almost a full tank. I havent really had time to use it much but changed the lambda (the one recommended on here from sparkplugs) and drove to get it tinted today and the fuel needle keeps falling like its was bungy-jumping. Do I really need to reset the ECU? The lambda should be feeding the ECU with fresh info all the time... ? Quote Link to comment Share on other sites More sharing options...
imi Posted June 19, 2011 Share Posted June 19, 2011 I came 8mpg when driving steady at around 80mph. 120-130miles you are right, that is not normal. check for the right lambda sensor reset ECU (maybe its still running in limp mode) do you have an AFR gauge, if so what sort of readings are you seeing. could be sparkplugs - what do they look like when you pull them out or maybe you have a leak.....check fuel lines. Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted June 19, 2011 Author Share Posted June 19, 2011 (edited) Have had the car on idle for longer periods and no dripping, fuel lines look fine (engine bay). Aint it strange that the car wont jump out of limp-mode when the new lambda is fitted? How long does the ECU need to be reset? I bought sparkplugs last week (am going to change all fluids etc also) but it does respond good and runs fine... Sadly no AFR gauge. Thanks. Edited June 19, 2011 by Thomas.B (see edit history) Quote Link to comment Share on other sites More sharing options...
johnny g Posted June 19, 2011 Share Posted June 19, 2011 Disconnet the negative terminal for 10-15 mins, then reconnect. Job done. Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted June 19, 2011 Author Share Posted June 19, 2011 Ok tried it and I guess I'll have to drive some to know if it helped. It came smoke when I started up (petrol) and then went away, guessing this is because the ECU was reset? Quote Link to comment Share on other sites More sharing options...
imi Posted June 19, 2011 Share Posted June 19, 2011 check the condition of the sparkplugs. might be even worthwhile using a fuel cleaner if the cars been running rich for a period of time. Quote Link to comment Share on other sites More sharing options...
Homer Posted June 19, 2011 Share Posted June 19, 2011 After resetting the ECU it'll need a 3-4 miles of regular driving to sort itself out. It certainly sounds like something is wrong as there's no way you should be getting those sort of mpg figures ouside of a trackday session. I think it was mentioned above, but do you have an AFR guage? Quote Link to comment Share on other sites More sharing options...
Havard Posted June 19, 2011 Share Posted June 19, 2011 That is scary MPG. Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted June 19, 2011 Share Posted June 19, 2011 Check the fuel lines under the car, if they are gunked over it will soak up the fuel & you wont see a drip. I just had the same prob with an l200. Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted June 20, 2011 Author Share Posted June 20, 2011 After resetting the ECU it'll need a 3-4 miles of regular driving to sort itself out. It certainly sounds like something is wrong as there's no way you should be getting those sort of mpg figures ouside of a trackday session. I think it was mentioned above, but do you have an AFR guage? Dont have an AFR, but the lambda is new. Is it normal that it gives a shitload of petrol when resetting the ECU (at startup)? It went away after driving a short distance. Dont think it leeks as I had it "on" (not started) for a long time and the fuel pump did not load. Quote Link to comment Share on other sites More sharing options...
Nic Posted June 20, 2011 Share Posted June 20, 2011 Is it normal that it gives a $#@!load of petrol when resetting the ECU (at startup)? Yes it take a few miles to relearn the settings after resetting the ECU. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 20, 2011 Share Posted June 20, 2011 Have you checked things like vacuum fed to fuel regulator, also the regulator itself, IAT sensor will have a big effect on cold start, but not so much once warmed up, it would also be worth checking the MAP sensor, although if there was a serious problem with it you would notice by the way It runs. Oh! and also check the ECU water temp sensor, as that will have a big impact on consumption if faulty. Quote Link to comment Share on other sites More sharing options...
