wesmi01 Posted January 18, 2003 Share Posted January 18, 2003 Jusy had the Supra down the work shop. 1. I now need a ERL water injection sensor. 2. Disks and pads all round. 3. Some rubber bushes at the back which seem to allow this clunking sound presently. If anyone has any ideas where to get these bits it would be of great help, prices etc!!!! It's a L plate jap sepc. Cheers Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted January 18, 2003 Share Posted January 18, 2003 Hi, 1. ERL might be your best bet! 2. Discs and pads I can do, depends which type your after though, all the ones I do are on my web site http://www.whifbitz.co.uk/suprabrakes.htm 3. Most of the rubber bushes aren't available seperately I believe, I'm pretty sure I enquired about this before and they come with the suspension arms which aren't cheap funnily enough. Paul Quote Link to comment Share on other sites More sharing options...
wesmi01 Posted January 18, 2003 Author Share Posted January 18, 2003 Paul, do you do just straight replacements!!! And what would the price be for the whole lot delivered. thanks. Mike Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted January 18, 2003 Share Posted January 18, 2003 What have you got? Jap or UK disc set up? Best off getting std discs with uprated pads, which pads depend if your going to do any track days or not? Quote Link to comment Share on other sites More sharing options...
Alex Posted January 18, 2003 Share Posted January 18, 2003 I think powerflex or Whiteline are your best best for suspension bushes. They are uprated poly bushes...much better for car control. Quote Link to comment Share on other sites More sharing options...
wesmi01 Posted January 18, 2003 Author Share Posted January 18, 2003 Cheers alex!!! There jap spec brakes, with hard road use really!!! Need back's and fronts!!! Quote Link to comment Share on other sites More sharing options...
wesmi01 Posted January 18, 2003 Author Share Posted January 18, 2003 Braking from massive speeds, not really into racing around the twisty bits!!! Quote Link to comment Share on other sites More sharing options...
Alex Posted January 18, 2003 Share Posted January 18, 2003 If you're breaking from high speed...you need to equip your car with UK brakes... You need bigger discs and calipers. Breaking from High speed needs similar qualities to track work. Though IMO you want good initial bite. Which is something CW's pads are rated for. Many have good results with Porterfields from Paul. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted January 18, 2003 Share Posted January 18, 2003 If you got for Porterfield R4 race pad you wont get any fade at all ever, they warm up quick as well, only problem being dust and sometimes squeal which normally happens when the copper slip wears off, if you keep reapplying it every now and again it will be ok though. Obviously a big brake upgrade will be better all round but if you can't afford it these will be a help. Also decent fluid and braided brake lines help a bit...If you can stretch to a brake conversion get yourself a KAD kit and you will no longer have any worries about your brakes, just total confidence in them. Paul Quote Link to comment Share on other sites More sharing options...
wesmi01 Posted January 18, 2003 Author Share Posted January 18, 2003 Alex do you mean from this link http://www.whifbitz.co.uk/suprabrakes.htm Race front pads £121.58* And on the same page where are the disks??????? Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted January 18, 2003 Share Posted January 18, 2003 I dont sell std discs unfortunately, I'd personally fit genuine Toyota discs if you can, your Toyota dealer should be able to supply them to you without problems. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 18, 2003 Share Posted January 18, 2003 Originally posted by Paul Whiffin I dont sell std discs unfortunately, I'd personally fit genuine Toyota discs if you can, your Toyota dealer should be able to supply them to you without problems. I can supply standard discs, also i do my own range of pads, as well as stock OE pads. I can help with Aquamist spares, too. Phone me, I won't be able to access e-mail much next week, I am away a lot. Quote Link to comment Share on other sites More sharing options...
