Jake Posted July 8, 2005 Share Posted July 8, 2005 Could one of the guys with a working EPC get me some part numbers for my 1993 RZ Auto please? Frame : JZA80-0008210 Model : JZA80-ALPQZ I need the following part numbers: Cambelt tensioner and Idler Wheel (Parts A and B in this picture) Water pump and gasket(s) Cambelt FEAD belt tensioner wheel and bearing. ("Fan belt" tensioner wheel and bearing) Thanks a lot! Quote Link to comment Share on other sites More sharing options...
jamesgtr Posted July 9, 2005 Share Posted July 9, 2005 Cambelt tensioner 13540-46012........49.65 + vat Idler...................13505-46041........55.27 + vat water pump.........16100-49846........110.92 + vat (include gasket & housing) fan belt tensioner.16620-0w022........104.13 + vat cambelt..............13568-49036.........23.68 + vat Quote Link to comment Share on other sites More sharing options...
Jake Posted July 9, 2005 Author Share Posted July 9, 2005 Thanks James! Those are the Toyota part numbers, right? £23.68 seems very cheap for a genuine Toyota cambelt. I'd appreciate an EPC exploded diagram of the cambelt tensioner assembly if anyone could get me one please. Quote Link to comment Share on other sites More sharing options...
jamesgtr Posted July 9, 2005 Share Posted July 9, 2005 Yep, genuine Toyota parts and numbers. If you weren't that far away, i could get them at 20% off for you There is no exploded diagram for the cambelt tensioner. Quote Link to comment Share on other sites More sharing options...
Jake Posted July 9, 2005 Author Share Posted July 9, 2005 I need to see where the idler stop and the tensioner starts, if you see what I mean. If the tensioner is just that wheel then I don't need one, mine is broken on the cast alloy bracket that the wheel is bolted to. Quote Link to comment Share on other sites More sharing options...
jamesgtr Posted July 9, 2005 Share Posted July 9, 2005 I think it's the wheel (called idler ) you want. It does have a little bracket attached to it. The other part below is called the tensioner. Hope this clears any confusion. I think it may be a good idea to change both. Quote Link to comment Share on other sites More sharing options...
Nic Posted July 9, 2005 Share Posted July 9, 2005 Jake, see attached visual from the EPC, if you need any others just let me know. Quote Link to comment Share on other sites More sharing options...
Jake Posted July 10, 2005 Author Share Posted July 10, 2005 Perfect. A picture paints a thousand words, eh? Thanks guys that's a great help Quote Link to comment Share on other sites More sharing options...
