Chris Wilson Posted June 18, 2011 Share Posted June 18, 2011 I now have a stock of front and rear pistons for UK calipers. I also have stainless brake pin kits for the UK calipers. i will sell as either full sets, or just fronts or rears as required. Fronts are £18 per piston and rears are £21 per piston. I also have the special material square section seals that go between the caliper halves when you split them to replace the pistons. These are not even listed, let alone available from Toyota. They are £4.50 each and there are two per caliper. They must be changed... P&P for pistons is £7.80 to UK postcode addresses, sent insured and trackable. Brake pin kits in stainless for all four UK calipers are £38 a set, plus £5.80 insured P&P, or at YOUR RISK, £2.50 by un-trackable Royal Mail parcel. I am hoping to offer caliper piston seals and dust / water boots shortly at a saving on Toyota prices, but for now you need to get these from a Toyota main agent. I am happy to rebuild calipers for people, but don't want to get involved painting or powder coating them. Payment by bank transfer or Paypal plus 4%. I do not take credit card payments, sorry. Orders by **E-MAIL** please. I have 24 fronts and 12 rears at the moment. J-Spec pistons coming very soon. By using stainless you will stop further seizure by chrome pitting and flaking and general rust on the standard Toyota pistons. If you don't know what you are doing take your calipers to a professional, the old pistons need to be nearly all the way out BEFORE you remove the calipers from the hydraulic system on the car!!!!! This means pumping them out evenly, with an assistant holding "eager" pistons back with a lever, with no pads in the caliper, one caliper at a time, then wedging the pistons that are almost out whilst you move to the next one, remove the pads and do the same again. Home made wooden wedges work fine. Link to comment Share on other sites More sharing options...
