NathWraith Posted June 17, 2011 Share Posted June 17, 2011 Hi guys, Just been looking on autobulbs direct and there is alot of LED "bulbs" you can get instead of standard bulbs for the Supra. Providing they are the same fitment (380 & 382 rear) they should fit and work no problem. I know LEDs use less power than standard bulbs but considering the Supra is an older car it shouldn't throw up any issues? Lastly anyone got any pics of said bulbs fitted or are they just too bright for road use. Bulbs in question Rear fog & indicator 382 http://www.autobulbsdirect.co.uk/382-24-LED-Bulbs-available-in-white-red-blue-green-amber.html?bulb_search=c25346 Rear brake lights 380 http://www.autobulbsdirect.co.uk/380-24-LED-Bulbs-available-in-white-red-amber.html?bulb_search=c25346 If I am making any noob mistakes by getting these then please tell me! Thanks in advance! Link to comment Share on other sites More sharing options...
NathWraith Posted June 18, 2011 Author Share Posted June 18, 2011 No one ever fitted LEDs before? Come on guys! Link to comment Share on other sites More sharing options...
suprasurrey Posted June 18, 2011 Share Posted June 18, 2011 The rear fog lights and brake lights should be alright, but the indicators could be a problem. The flasher relay is set up to work on a specific current draw, and going from 21watts to 1 watt may slow the flash rate or stop it althogether. Link to comment Share on other sites More sharing options...
heckler Posted June 18, 2011 Share Posted June 18, 2011 The rear fog lights and brake lights should be alright, but the indicators could be a problem. The flasher relay is set up to work on a specific current draw, and going from 21watts to 1 watt may slow the flash rate or stop it althogether. The flash rate will increase, not slow down... Link to comment Share on other sites More sharing options...
NathWraith Posted June 18, 2011 Author Share Posted June 18, 2011 The rear fog lights and brake lights should be alright, but the indicators could be a problem. The flasher relay is set up to work on a specific current draw, and going from 21watts to 1 watt may slow the flash rate or stop it althogether. Ah I see. So a resister would have to be used I guess? Link to comment Share on other sites More sharing options...
heckler Posted June 25, 2011 Share Posted June 25, 2011 Ah I see. So a resister would have to be used I guess? You might be ok, as I "think" the led replacement bulbs take the resistor into account, but don't quote me on that! Link to comment Share on other sites More sharing options...
SteveC Posted June 25, 2011 Share Posted June 25, 2011 I tried some that looked very similar to those in the link. The light output was very poor compared to the standard bulbs, so I ended up putting those back. Link to comment Share on other sites More sharing options...
Digsy Posted June 27, 2011 Share Posted June 27, 2011 LEDs bulbs are very bright when viewed from up to approx 20 degrees from directly behind the car. Anything at more of an angle than that (with those style bulbs) will not see much light at all. I think these type of rear bulbs are pretty unsafe for that reason - especially for indicators). You can get special bulbs with LED elements pointing in different directions to overcome this issue, but I suspect they might cost a bit more. Link to comment Share on other sites More sharing options...
