Guest v8_project Posted June 17, 2011 Share Posted June 17, 2011 For sale Toyota JZZ30 Soarer Standard shocks+springs piezo dampers fits JZA80 Supra, though I'm not sure if the supra uses the same piezo system? These cam off a car with 60k on the clock, taken off due to coilover upgrade. All working well when taken off with no leaks or noises. These are the Piezo controlled damper ones that stiffen up the dampers under acceleration (rear) breaking (fronts) and cornering . You will need the rest of the electronics in the car to simply plug and play. Or if you want rest of hte Piezo electronics from my car (and know how to take it out!) you are welcome to it Looking for £50 for fronts, £50 rears or £90 for the lot + postage of £9.99 per pair. Or collect from Bristol or Cheltenham (or nearby) http://www.motorbikesandparts.co.uk/temp/IMG_1013.JPG http://www.motorbikesandparts.co.uk/temp/IMG_1014.JPG Link to comment Share on other sites More sharing options...
Guest v8_project Posted June 18, 2011 Share Posted June 18, 2011 Prov SOLD! Link to comment Share on other sites More sharing options...
