Blitz Nur Spec Exhaust Backboxes
Guest v8_project
Guest v8_project
I have put these on ebay
Blitz Nur Spec Exhaust Backbox X 2 Toyota Soarer, not sure if they will simply bolt on to the Supra system,
designed to bolt on to the standard Soarer 1JZ exhaust system, but could be made to fit any exhaust system by your local exhaust specialists.
The entry pipe is about 2.5 inches, the exit is just a little less than 4.5 inches.
There is some scuffing to the bottom where it has caught on speed bumps, but not visable when on the car and doesn't affect the sound or performance.
These are performance back boxes and are loud. I have been told they were £550 when new
Blitz Nur Spec SR Exhaust Backbox X 2 Toyota Soarer 1JZ | eBay UK
Well this is the standard Nur Spec S for the Supra that joins onto the stock Y-Pipe which I actually have. Couldn't say whether it could be made to fit or not http://cgi.ebay.co.uk/BLITZ-NUR-SPEC-S-EXHAUST-TOYOTA-SUPRA-TWIN-TURBO-JZA80-/270451912597?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3ef830af95
The standard Supra system has a Y-Pipe that goes into the backbox so it needs two smaller input flanges, or if you wanted to try and make it fit with the one flange then make a pipe from the cat-back to mate up with it to replace the Y section
