Single Turbo conversion
Guest AI99
More info here:
http://garagewhifbitz.co.uk/frontpage/garage-whifbitz-twin-wastegate-supra-turbo-kit/
http://www.powerhouseracing.com/Templates/frmtemplateM7.asp?SubFolderID=25&SearchYN=N
You're lucky in where you live, you've got Whifbitz, SRD and AFR all within a decent distance, all of whom will be able to advise, supply and fit whatever kit you want.
We generally consider £10k to be a starting figure for a basic single Kit supplied, fittedvand mapped on a TT. However, there's many extras that may be required (ie clutch) so it's best to have a few £k set aside for extras.
Edited by j_jza80 (see edit history)
:yeahthat:
What is your budget for the single conversion? Unless you are prepared to pay £10K+ I'd say don't bother, if you try to do on a budget - using cheap parts - or cut corners - not fit all supporting mods required - you will end up with either an unfinished project or a car that is unreliable that will end up costing you far more to put right.
Fast - Reliable - Cheap
