Tyson Posted June 16, 2011 Share Posted June 16, 2011 Just fitted my stormforce car cover and it's great but there is one problem. It was designed for cars without headlight washers! So the front doesn't stretch far enough, if I pull it too tight it puts strain on the washers. just something to take into consideration when getting one if you have a uk spec. Plus one of the under car straps is defective. Apart from that it's worth every penny. Quote Link to comment Share on other sites More sharing options...
Havard Posted June 16, 2011 Share Posted June 16, 2011 (edited) Just fitted my stormforce car cover and it's great but there is one problem. It was designed for cars without headlight washers! So the front doesn't stretch far enough, if I pull it too tight it puts strain on the washers. just something to take into consideration when getting one if you have a uk spec. Plus one of the under car straps is defective. Apart from that it's worth every penny. Just cut two little holes in the front and let the dildos pop out..!! I must admit, there isn't a great deal of play in them but for a stock bodies J-spec they are perfect. If you give Stormforce a call and tell them about the clips, they will send you a couple as spares. They have been great whenever I have rang them. H. Edited June 16, 2011 by Havard (see edit history) Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 16, 2011 Share Posted June 16, 2011 Clips broke on mine shortly after getting it, ive always used bungee straps under the car and its been a great cover. Quote Link to comment Share on other sites More sharing options...
Tyson Posted June 16, 2011 Author Share Posted June 16, 2011 Just cut two little holes in the front and let the dildos pop out..!! I must admit, there isn't a great deal of play in them but for a stock bodies J-spec they are perfect. If you give Stormforce a call and tell them about the clips, they will send you a couple as spares. They have been great whenever I have rang them. H. Yeah am going to five them a bell tomorrow, like you say they are a snug fit and there isn't much wiggle room. Quote Link to comment Share on other sites More sharing options...
Havard Posted June 16, 2011 Share Posted June 16, 2011 Mine had a dodgy clip when I got it and they sorted it out with a new one in the post. I then trod on one of the clip holders and broke it on the drive. Rang them again and told them what I had done and they just sent two FOC in the post. H. Quote Link to comment Share on other sites More sharing options...
