Polished my stock rear 16s
Neil-NA
Not alot of pics i'm afraid as i just wanted to get them done as fast as possible.
Heres the steps i used to get the the point im at now -
1. Nitromors to remove the silver paint.
2. 600 grit wet/dry to get to a reasonably smooth finish
3. Drill with 400 grit abrasive and wheel to remove as many imperfections as possible.
4. 3 stage polish using various mops and polishing compunds (i still have 2 steps to go after these pics.
So far i have only managed to do the spokes, still the centre and outer edges/ inbetween the spokes left to do, time taken so far is around 6 hours but i aim to get the second wheel completely done in less than 4.
They are by no means perfect but i think it is a slight alternative to either painted or stock coloured wheels.
I am only going to use them at Suprapod so not really worried about cleaning them etc.
I dont have the centre caps, was just going to use them like this, would look odd with plastic centres anyways lol.
Good work that Neil :thumbs:
My rear hub nuts show when I take the centre caps off, is there supposed to be a cover?
  • 2 weeks later...
Right quick update.
I started the second wheel today, basically trying to get them both finished asap.
After Nitromors it looked like this -
Once over with 80 grit ( i decided not to use wet/dry as its quite time consuming)
I will update during the day for anyone interested. Next step is finish all the little bits with the 80grit then move onto 180 then 400, then use the 3 polishing wheels.
Maybe a couple of coats of lacquer on them after they're done might preserve the finish?
If I had a spare set of stock wheels, I'd do this as well, if they can be easily maintained.
Good job so far. :)
yeah it would, thats what i done on my gearbox.... sealed it with clear coat.
I'm interested. Can you post pics of them on the car too. :)
As soon as they are finished i will do some pics bud.
Good job so far. :)
I might just do a couple of coats, i am only using them for suprapod (yes all this work for one day)
