Pressure plate/flywheel allignment?
Homer
Hopefully a simple one for those in the know...
The locators on the pressure plate do not line up exactly with the steel pins on the flywheel. I can get any two pins to fit snugly, but the 3rd is about 0.2-0.4mm out, it's only very slightly out, but the plate can't be pushed onto the flywheel by hand.
Is it just a case of using brute force to get it on located on the pins, or is this a problem with the flywheel/pressure plate? The flywheel is 2nd hand but in very good condition.
