Driver Fuse Box Layout.
Whitelightning
Helloooooo
Is this fuse box under the side kick panel on the driver's side? If so, I can't find any fuses under mine - just a few looms loomin' underneath. Where is it exactly?
Cheers
Paul
:innocent:
You don't have to remove the panel to get to it. In the drivers side. Just slightly masked by carpet.
Ah, cheers RoGuEsTeR!
I wondered what the hell was going on when I removed my kick panel - only to find no fuses at all! Well, apart from a few inline ones shoved in there for good measure. Anyone know what they are for??
Ta Bud!
Paul
:respekt:
Sorry for hijacking your post WL !!
Paul
:p
  • 10 months later...
If you have this fuse box have you still one under the bonnet? As i have blown the fuse for my interior dash lights and indicaters yet im not sure which ones they are, if they are the ones under the bonnet(if that makes sense. Sorry typical girlly thing!
I can't remember off hand, best bet is to check under the bonnet and in the footwell.
The interior light is more than likely in the drivers footwell.
Edit: I think the fuse called "gauge" is for the interior lights but i am not 100 %
Sorry to resurrect such an old thread, but I've got a problem with my windows. They worked perfectly last night, and this morning nothing. Neither one worked, just dead.
I'm assuming the fuse has gone, but even using the diagrams on this thread I can't tell which fuse would be for the windows, unless its in the fuse box under the bonnet.
Can anyone help?!
Can anyone help?!
I normally check the electrical manual on Mkiv.com
The window circuit is here:
