Driver Fuse Box Layout.
Whitelightning
By the looks of it, the passenger window switch works on that side. It may well be something to do with the window switch on the driver's door. How easy is it to remove the little panel there to have a look?
From memory you have to remove the door card.
A guide to it can be found on Hecklers website: http://www.internetwork.org.uk/Dash%20Conversion/doorrem.htm
  • 5 months later...
  • 1 month later...
It's on the inside of the fuse box lid/cover.
sorry should have mentioned I don't have the cover - though if you have seen some of my previous posts then it would have been a fair assumption that I could be that stupid;)
anyway I understand the VVTI fuse layout is different - so looking for a diagram/pic of driver footwell fuse box cover for 98 TT TIP VVTI
thanks,
Seán
