bullet_uk Posted June 13, 2011 Share Posted June 13, 2011 when on my drive home tonight i had a run in with a boy in what i can only guess was his new bmw anyway i knew i had the edge and put my foot down anyway i looked down at the clock and i had hit the 110mph on the clock but yet the supe was still pulling like there was no tomorrow so my question is as the title what should be the top end Quote Link to comment Share on other sites More sharing options...
bullet_uk Posted June 13, 2011 Author Share Posted June 13, 2011 If no one guessed by that post i have a 110mph clock Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted June 13, 2011 Share Posted June 13, 2011 mine hits the limiter in 5th at 163mph,its been tweeked abit so im guessing a standard na will do 150mph no worrys.its a good strong engine with superb reliability! Quote Link to comment Share on other sites More sharing options...
Guigsy Posted June 13, 2011 Share Posted June 13, 2011 my 5 speed got up to 140 on the speedo but it will have been over reading. an NA probably wont reach its theoretical top speed. and will take a very very very very long piece of road to get there. Quote Link to comment Share on other sites More sharing options...
bullet_uk Posted June 13, 2011 Author Share Posted June 13, 2011 thanks i have a 180mph clock i need to put on i was just unsure about putting it in just in case it didn't give a true reading but i think i will now Quote Link to comment Share on other sites More sharing options...
Abz Posted June 13, 2011 Share Posted June 13, 2011 mine hits the limiter in 5th at 163mph,its been tweeked abit so im guessing a standard na will do 150mph no worrys.its a good strong engine with superb reliability! 163mph? You sure the speedo wasn't over reading? Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted June 13, 2011 Share Posted June 13, 2011 163mph? You sure the speedo wasn't over reading? had this conversation on here before buddy its out by 7mph (checked on gps) it hits the limiter in top gear.the car runs 14.3s on the quarter,see hall of fame Quote Link to comment Share on other sites More sharing options...
Abz Posted June 13, 2011 Share Posted June 13, 2011 had this conversation on here before buddy its out by 7mph (checked on gps) it hits the limiter in top gear.the car runs 14.3s on the quarter,see hall of fame Ah that sounds about right then, I think I remember now Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted June 13, 2011 Share Posted June 13, 2011 Ah that sounds about right then, I think I remember now yes yes i got ripped and forced to find my timing slips! was a fun night that one! Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted June 13, 2011 Share Posted June 13, 2011 I have had 150mph on the clock (guessing that be between 135 and 145 if honest) out of mine have also got 180 speedo in dash Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted June 14, 2011 Share Posted June 14, 2011 Probably 140ish, but as said, that'll take ages. I wouldn't bother Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 14, 2011 Share Posted June 14, 2011 Depends on what you consider ages. Mine seems to want to keep going. My NA will hit 160+ speedo, which according to sat nav on all occasions ive done it, works out at 151mph Quote Link to comment Share on other sites More sharing options...
Scott Posted June 14, 2011 Share Posted June 14, 2011 As above I reckon you will hit a true 150 and a speedo 160ish. Engine will need to be very healthy to hit those speeds though, with as many horses as Toyota first put in there. It'll take a helluva long road to do it on though, much like trying to hit 190 in a bpu. Downhill, with the wind at your back might take a little less time. Had the discussion before but I reckon the car will pull a reasonable 140. Quote Link to comment Share on other sites More sharing options...
Nic Posted June 14, 2011 Share Posted June 14, 2011 Theoretical speeds through each gear Quote Link to comment Share on other sites More sharing options...
preston7 Posted June 14, 2011 Share Posted June 14, 2011 If you drive at 1/2 revs in top gear then double it that will give your theoretical top speed, assuming that you can reach full revs in top gear and that the speedo is accurate. Quote Link to comment Share on other sites More sharing options...
preston7 Posted June 14, 2011 Share Posted June 14, 2011 oh and on my NA, on my speedo I have been just past 145 before backing off, I havent however driven with a sat nav in yet so havn't had any way of checking how accurate my speedo is Quote Link to comment Share on other sites More sharing options...
jackso11 Posted June 14, 2011 Share Posted June 14, 2011 on an old air strip I got my old NA up to 148, doubt it would have gone much over that and taking into account how far out supras speedos are as standard it was probably 135mph or there abouts. Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted June 14, 2011 Share Posted June 14, 2011 Using Homers calculator - http://www.mkivsupra.net/vbb/showthread.php?225050-Supra-specific-gear-diff-ratio-and-tyre-size-calculator you can find the top speed in each gear using your tyre size, diff ratio, gearbox etc Quote Link to comment Share on other sites More sharing options...
AlexJames Posted June 14, 2011 Share Posted June 14, 2011 on my bpu+ twinturbo i got 163mph...on a private road.... (gps speed, clock was well over 180 lol) Theoretically, what should a BPU+ supra top speed be? Quote Link to comment Share on other sites More sharing options...
Scott Posted June 14, 2011 Share Posted June 14, 2011 on my bpu+ twinturbo i got 163mph...on a private road.... (gps speed, clock was well over 180 lol) Theoretically, what should a BPU+ supra top speed be? You should be able to pull around 180 (true speed). If you have a full on 430hp bpu car you should get to around 190 on a long enough straight. Good luck finding one though. Quote Link to comment Share on other sites More sharing options...
AlexJames Posted June 14, 2011 Share Posted June 14, 2011 Impressive, I ran out of road (and bravery) so had to slow... interesting to know it will hit that kinda speed! Quote Link to comment Share on other sites More sharing options...
dive_popo Posted June 14, 2011 Share Posted June 14, 2011 I hit 185 mph with no problem on my bpu (stock wheels), speed is awesome but braking...... already tested my speedo with 2 diffrent gps and its ok Quote Link to comment Share on other sites More sharing options...
ilicos Posted June 14, 2011 Share Posted June 14, 2011 I managed 156mph with my tom tom as guide. Milometer was showing 168+ W58 btw Quote Link to comment Share on other sites More sharing options...
Nic Posted June 14, 2011 Share Posted June 14, 2011 (edited) Theoretical speeds through each gear Based on the above link, speeds converted to mph. No code has to be inserted here. *2JZ-GTE/V161 has higher 7200rpm rev limit Edited June 14, 2011 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
AlexJames Posted June 14, 2011 Share Posted June 14, 2011 Based on the above link, speeds converted to mph. No code has to be inserted here. *2JZ-GTE/V161 has higher 7200rpm rev limit Quote Link to comment Share on other sites More sharing options...
