Flywheel knackered
Guest Budz86
Guest Budz86
I've been having problems with my BPU 6 speed and not being able to get the power down. Feels like it's the clutch as when boosting over 0.9 bar it's starting to slip. Also feels a bit slugish low down but when I'm booting it in 4th/5th it seems to be accelerating better.
I've not noticed any problems when driving round town normally (car is a daily driver) but the bite point is quite high. No noises either which I thought was a symptom of a knackered flywheel. Might have a slight judder but if it is happening I've put it down to me not being smooth with the peddle.
What sort of things should I be seeing/hearing/feeling if the flywheel is shot?
if the clutch plate gets worn down to the rivets it can score the flywheel.
if you put the handbrake on. Put the car in 2/3 gear and lift the clutch pedal as if to pull away if the cars revs just go up and the engine doesn't try to stall the clutch is on its way out.
