Aero-M Posted June 10, 2011 Share Posted June 10, 2011 http://cgi.ebay.co.uk/300535350162?ru=http%3A%2F%2Fshop.ebay.co.uk%3A80%2Fi.html%3F_from%3DR40%26_trksid%3Dm570%26_nkw%3D300535350162%26_fvi%3D1&_rdc=1 My van doesn't have an alarm but was told by a local car audio installer these are what they fit, it uses your current ford key fob to activate. They charge £250 plus the vat to fit these so I wondered if anyone has fitted one how hard are they? It would save me £200 to fit this myself. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted June 10, 2011 Share Posted June 10, 2011 Used to fit these a lot, not too difficult. Most of the block connectors are within easy reach, not much soldering to do either. I'd set aside a weekend to get it perfect if you've never done one before. Get a multimeter, some solder & heatshrink. Don't twist & tape the wires, its just a nasty bodge that wont last 5 minutes. Need any help, drop me a PM. Quote Link to comment Share on other sites More sharing options...
Aero-M Posted June 11, 2011 Author Share Posted June 11, 2011 Used to fit these a lot, not too difficult. Most of the block connectors are within easy reach, not much soldering to do either. I'd set aside a weekend to get it perfect if you've never done one before. Get a multimeter, some solder & heatshrink. Don't twist & tape the wires, its just a nasty bodge that wont last 5 minutes. Need any help, drop me a PM. Ok will do, thank you. Instructions look like it just plugs into the existing wiring, then run cables for the door sensors etc. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted June 11, 2011 Share Posted June 11, 2011 If its a multiplexed system then your laughing, plug and play, + a couple of wires to the -12 side of the pin switches. If it's an older Quote Link to comment Share on other sites More sharing options...
