skippyboyo1 Posted June 9, 2011 Share Posted June 9, 2011 (edited) Right guys ive looked around using the search button but i cant seem to find the right answer. Im holding my hands up ive no idea about offsets so here is my question........ I Have rolled all 4 of my arches and im running lowering springs so the car is not "slammed" or anything and im looking to fit 18" wheels (love the look of 19" but i do alot of trackdays and i just dont think 19" is the way to go) The wheels i want are rota torque so whats the widest 18" rims i can get on,i was thinking 9" front and 10" rear however ive no idea about which offset to go for? thanks in advance guys also to be a pain can anyone recommend where the best place to get rota's from? Edited June 9, 2011 by skippyboyo1 (see edit history) Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 9, 2011 Share Posted June 9, 2011 With a rota 9" front and 10" rear go for a 35ish offset all round and you will be fine, you can go lower if you want, my rota svn's on the V8 are 9"et25 front and 10"et30 rear, it dont rub but its very close, Whifbitz beats everyone on price by miles when i was looking. You can go wider with other wheels, CCW classics do a 11.5" rear that fits under a stock rolled rear arch. Quote Link to comment Share on other sites More sharing options...
monsween Posted June 9, 2011 Share Posted June 9, 2011 Check out marcab10. he's running pretty wide wheels on stock arches Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted June 9, 2011 Author Share Posted June 9, 2011 With a rota 9" front and 10" rear go for a 35ish offset all round and you will be fine, you can go lower if you want, my rota svn's on the V8 are 9"et25 front and 10"et30 rear, it dont rub but its very close, Whifbitz beats everyone on price by miles when i was looking. You can go wider with other wheels, CCW classics do a 11.5" rear that fits under a stock rolled rear arch. thought you would know this one jamie. what do you think to the 19" rim compared to the 18" then? i feel the car handles real well in my current 18" and i just dont want to upset that. Right so 35 offset all round is the way to go then Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted June 9, 2011 Author Share Posted June 9, 2011 Check out marcab10. he's running pretty wide wheels on stock arches my arches are rolled but ill have a look Quote Link to comment Share on other sites More sharing options...
monsween Posted June 9, 2011 Share Posted June 9, 2011 my arches are rolled but ill have a look they are rolled flat too Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted June 9, 2011 Author Share Posted June 9, 2011 they are rolled flat too yup just been reading his thread Quote Link to comment Share on other sites More sharing options...
marcAB10 Posted June 9, 2011 Share Posted June 9, 2011 yeah i'm running 11" rears and 9.5" fronts on stock rolled arches, although i went with an aggressive offset so they have some 'poke', if you chose a higher offset (my rears are +22) then they should fit flush and you can run a wider tyre. Quote Link to comment Share on other sites More sharing options...
Kris H Posted June 10, 2011 Share Posted June 10, 2011 i'm running 10" fronts and 13" rear but they are Ccw's so i dont know the offset, Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted June 10, 2011 Author Share Posted June 10, 2011 i'm running 10" fronts and 13" rear but they are Ccw's so i dont know the offset, 13"! my god!!!!! do they scrub at all?? Quote Link to comment Share on other sites More sharing options...
Kris H Posted June 11, 2011 Share Posted June 11, 2011 13"! my god!!!!! do they scrub at all?? with 345/30 BFG's it was silly, the tirewall rubbing against the suspension and lots of tire outside the arches, but on 315/30 there is no problem -depends on the tire too, the BFG T/A's have massive drag'ish tyrewall's I have tried to messure the offset and i think its +50 ? dont know if that helps. Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted June 12, 2011 Author Share Posted June 12, 2011 with 345/30 BFG's it was silly, the tirewall rubbing against the suspension and lots of tire outside the arches, but on 315/30 there is no problem -depends on the tire too, the BFG T/A's have massive drag'ish tyrewall's I have tried to messure the offset and i think its +50 ? dont know if that helps. it does thanks buddy Quote Link to comment Share on other sites More sharing options...
