Will these brakes fit my N/A?
sweetcal66
Hi people just wondering if anyone knows if these brake discs will fit my 1993 N/A supra as my discs are shot and i am low on funds as i am away on holiday next week and need them sorted before i go????
http://cgi.ebay.co.uk/TOYOTA-SUPRA-MA70-Drilled-Brake-Discs-Rear-Pads-/290363978288?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item439b0ab230
All help appreciated
cheers
Edited by Gaz6002 (see edit history)
The Supra was fitted with 2 brake options, you need to know which you have so you can order the correct size discs. If you're not sure post up some pics so we can identify them.
Smaller spec brakes
2 pot front calipers - 296mm diameter discs
1 pot rear calipers - 307mm diameter discs
Larger spec brakes
4 pot front calipers - 323mm diameter discs
2 pot rear calipers - 324mm diameter discs
so am propa confused now someone has offerd me the same ones that he bought for his n/a supra are they gunna fit?? cheers
The NA Supra came factory fitted with 2 brake options - see earlier post for details - you need to know which brakes you have fitted so you can get the correct size discs.
