TT water temp sensors,which 1 does what??
hodge
Hi guys
I'm making a custom loom for my car and removing all the un-needed wiring.
Am I correct in thinking the small water temp sensor with the single wire is for the water temp gauge on the dash and the larger sensor is to the ECU.
Thanks
John
  • 2 months later...
  • 10 months later...
Top water elbow bud. There's 2 sensors, the 1 with the single wire in it is for the dash. Odds are the wire has snapped off it. It's a common issue.
So I have the same idea as you, hodge removing any un wanted wiring. I have a syvecs fitted and have a lead that goes to thetop rad hose from the syvecs, can I do away with the other 2 sensors or leave the one with one wire for the dash? Chances are the origonal sensor is not plugged in to anything right?
But the syvecs has its own coolent temp sensor going to it. I think the oem ecu is just controlling the auto box.
Are you sure, I can't see why it would have its own sensor. Ryan just calibrated the stock sensor. That way you can use the stock wiring instead of adding more.
Well theres 3 new wires that come from the passenger side grommet and one goes to the intercooler piping just before the tb and one goes to the top rad hose and the other is oil temp under the intake somewhere. Heres a pic you can see on the top rad hose a sensor -
I guess it does then, but can't understand why though, nor can I understand the blue spaghetti around your turbo :p
Haha I cant either but i`ll get to that bit eventually :) I`ll have a word with ryan and see whats what then I know what can go!
