re: MOT emissions failed :D
The Hornet
Just took her in for MOT and it failed only on emissions.
Thought I would just stick it in to see what they said - hehe
Results:
Fast idle speed - CO =
Second Fast idle - CO =
\some other symbol - 0.970 - 1.030 - mine = 1.040 = Fail
All the other lines on the sheet was either a pass or not checked...
Have to take me 2 CATS in on Monday for them to re-fit & re-test :(
Are the above about what mine should be reading at BPU+ ?
Hornet
Good readings for the girl without any cats in mate. All looks fine and will fly through I would of thought with just 1 cat in.
I have heard sticking the silencer in the back does help, as reading can get a bit in-accurate with just a big tail pipe.
The "symbol" is the LAMBDA sensor readings. Again, does not look too bad.
Nope SAFC as yet, just waiting for turbo's to blow, then its bigger injectors, SAFC, and a T60/ T61 for me :D
Just read you other post, I guess my results helped then, and she is running on 97RON BP Ultimate at the time too (as 98ron shell is rare around here).
