toyota emblem removal
suprarob
The front one has two post pins that hold it on the front cover. The best thing to do is pull back the cover and cut them from behind. You should be able to just undo the small bracket under the bonnet which is held in place by five plastic push pin clasps under the rubber seal. This will release the top part of the bumper cover enough for you to clip the emblem pins or pry off the little friction fittings that hold it in place.
