Dyer864 Posted June 4, 2011 Share Posted June 4, 2011 Hi all ! Few weeks ago, my horn give up the ghost after breaking an earth wire after fitting an after market steering wheel ! got the wire attached again, but soon as i press the horn the fuse blows an auto electrician was just going to run a seperate switch,but after inspecting the horn, it wasn't from the horn on steering wheel to the fuse box, it was from the fuse box to horn siren itself ! Disconnected horn siren , but he has asked if there is a second horn hidden away somewhere under the front by rad. as he couln't work it out why the fuse box was showing an error. but didn't av time to go any further as he was doing me a fav. just aving a look Is there a second Horn siren , and located where please Link to comment Share on other sites More sharing options...
merckx Posted June 4, 2011 Share Posted June 4, 2011 (edited) There are two. I'm not sure if the orientation is correct as sometimes they're different on left hand drive cars. Edited June 4, 2011 by merckx (see edit history) Link to comment Share on other sites More sharing options...
Dyer864 Posted June 4, 2011 Author Share Posted June 4, 2011 I've taken the left hand side one off, so the one in the middle is the bugger ! Thanks merckx Link to comment Share on other sites More sharing options...
Lude Posted June 5, 2011 Share Posted June 5, 2011 (edited) yep 2 horns, i have also removed one of mine. (as it was bright red & stood out like a soor thumb) on my old car, someone had cut the wire off by the steering column so coudnt activate the horn inside the car. so i just ran a wire direct from the horn to the car & earthed. all a horn needs is 12v posotive to sound, so just make the steering wheel button the switch in the circuit Edited June 5, 2011 by Lude (see edit history) Link to comment Share on other sites More sharing options...
Dyer864 Posted June 5, 2011 Author Share Posted June 5, 2011 ok cheers lude .yep 2 horns, i have also removed one of mine. (as it was bright red & stood out like a soor thumb) on my old car, someone had cut the wire off by the steering column so coudnt activate the horn inside the car. so i just ran a wire direct from the horn to the car & earthed. all a horn needs is 12v posotive to sound, so just make the steering wheel button the switch in the circuit Link to comment Share on other sites More sharing options...
skippyboyo1 Posted June 5, 2011 Share Posted June 5, 2011 or failing that jut put it to a switch on the dash (it will still pass an mot as long as its in reach) Link to comment Share on other sites More sharing options...
