paulj1 Posted June 3, 2011 Share Posted June 3, 2011 Hi guys couple months ago my steering went really light with not much feel any one got any ideas? Cheers Paul Quote Link to comment Share on other sites More sharing options...
SimonB Posted June 3, 2011 Share Posted June 3, 2011 Probably the speed signal to the power steering ECU has gone. If you have a kph/mph convertor I'd check the wiring. If it's wired wrong the car can think it's going slower than it is and it gives more assistance. If it goes completely you'll get max assistance all the time. It would normally throw an error code though. Quote Link to comment Share on other sites More sharing options...
paulj1 Posted June 5, 2011 Author Share Posted June 5, 2011 Yer i get max assistance all the time will try get it booked in to garage see if they're any fault codes Quote Link to comment Share on other sites More sharing options...
bignum Posted June 5, 2011 Share Posted June 5, 2011 You can check your own fault codes, see here, http://www.mkivsupra.net/vbb/showthread.php?235771-fault-diagnostics-help..............-with-video&highlight=fault+codes Quote Link to comment Share on other sites More sharing options...
Nic Posted June 5, 2011 Share Posted June 5, 2011 Hi guys couple months ago my steering went really light with not much feel any one got any ideas? Cheers Paul Did you fit a speed delimiter, speedo convertor or other electronics before you noticed the difference? Quote Link to comment Share on other sites More sharing options...
2soops Posted June 5, 2011 Share Posted June 5, 2011 Have you hit any kerbs/pot holes and put the tracking alignment out, check to see if the outside or inside edge of the tyre is wearing out Quote Link to comment Share on other sites More sharing options...
