my big twin turbo build
Stephen G
  • Replies 69
Nice build matey, I'm glad the love is back. :) Luuurrrvvve that colour too. :drool:
  thetrashcanman said:
Jamsey is, but he's still Auto, I'd like to see what difference will be with the 6 speed
The Do-Luck IS 6 speed with the auto diff. ;)
Test fitted the remade down pipe which i'm very pleased the way it turned out.
The thick peace of metal under the rear turbo is a spacer as i wanted to rise the turbo 1" for a bit more clearance from the strut mount. The one in the picture is only a rough guide as i'm getting a proper one cut tomorrow.
  • 3 weeks later...
Dropped the front suspension and cradle out of the car.
was going to polybush the arms but when i checked them after i had everything took apart they are like new. When i bought the car it had almost full toyota service history so i'm thinking that the arms most have been replaced some time.
Some of the suspension in bits.
The missing bits are away getting bead blasted and painted and these parts will get done aswell.
My brother doing it at his work and cant take everything at the one time:sly:
  • 9 months later...
a bit of a update for you guys, has been a while since i have done one so here we go.
suspension back in all checked ,painted ect, the thick black cable in this pic is the new battery lead before it was routed.
and have the engine back in with greddy type plenum fitted and fuse box moved
radiator in and oil cooler
and getting some of the new turbo pipe work done
have started to make up the boost pipes for the turbos and should have them finished tomorrow and will get some pics of them up when they are done.
Edited by Stephen G (see edit history)
  • 1 year later...
Its been a long time since i have posted a update so this is how the supra is now
Its still not finished as you can see but almost there. Only a few minor things left to do engine bay wise, turbo blankets, managment system, boost control etc.
The front half of the car still needs painted wing bonnet and bumper which i might change to a jap and loose the headlight washers and get the centers of the new wheels painted a different colour.
