mellonman Posted December 1, 2011 Author Share Posted December 1, 2011 thought i better up date this the problem with the boucing afrs is that the stock ecu and fic are fighting each other it is important to get the injector responce time and the fuel trims as correct as you can! if they are off by even the smallest setting the afr will bouce as the ecu thinks its gone lean and put fuel in but the responce time or trim might be out and it may put too much fuel in and then the ecu goes rich and so on Quote Link to comment Share on other sites More sharing options...
