Warning lights came on
jay5041
The engine will feel very hot on a day like today.
The main warning triangle lights up when the ECU detects a fault, are there any other warning lights coming on at the same time?
The most common reason for the warning light to come on is low brake fluid, the sensor is very sensitive, even if it is just below the full mark it can come on. Try topping it up and see if that cures it.
I would do an ecu reset, remove EFI fuse number 1 for 30s or more.
  • 11 months later...
