dive_popo Posted June 3, 2011 Share Posted June 3, 2011 Hi, I just bought a set os lexus gs300 sport rims i'm wondering about the tire size that i can put on these... and i have no idea ! What is the maximum size ? 'cause I want the largest possible on these:D Thanks Quote Link to comment Share on other sites More sharing options...
Josh Posted June 3, 2011 Share Posted June 3, 2011 What size are the wheels first? Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 3, 2011 Share Posted June 3, 2011 Are the wheels 18 x 8.5 front and 18 x 10" rear ? If so the optimum sizes are Front 235 or 245 Rear 265 or 275 Quote Link to comment Share on other sites More sharing options...
Guigsy Posted June 3, 2011 Share Posted June 3, 2011 My rears are the same width but I've got 255 on them and they look perfect. Which is interesting. I wonder if I'll stop spin in 1st with some slightly bigger. I always imagined they would look odd Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 3, 2011 Share Posted June 3, 2011 My rears are the same width but I've got 255 on them and they look perfect. Which is interesting. I wonder if I'll stop spin in 1st with some slightly bigger. I always imagined they would look odd 255 is really the narrowest size you should fit on a 10" rim going up to 285 being the widest. Wheel and Tyre sizes Here is a usefull guide along with a tyre calculator You should use the tyre calculator to get the correct profile to keep the rolling radius close to o/e, http://www.etyres.co.uk/tyre-size-calculator.htm Rim width---Min tyre width----Ideal tyre width-------Max tyre width 7.0 inches-----195 mm--------205 or 215 mm-----------225 mm 7.5 inches-----205 mm--------215 or 225 mm-----------235 mm 8.0 inches-----215 mm--------225 or 235 mm-----------245 mm 8.5 inches-----225 mm--------235 or 245 mm-----------255 mm 9,0 inches-----235 mm--------245 or 255 mm-----------265 mm 9.5 inches-----245 mm--------255 or 265 mm-----------275 mm 10.0 inches----255 mm--------265 or 275 mm-----------285 mm 10.5 inches----265 mm--------275 or 285 mm-----------295 mm 11.0 inches----275 mm--------285 or 295 mm-----------305 mm 11.5 inches----285 mm--------295 or 305 mm-----------315 mm 12.0 inches----295 mm--------305 or 315 mm-----------325 mm 12.5 inches----305 mm--------315 or 325 mm-----------335 mm Quote Link to comment Share on other sites More sharing options...
Guigsy Posted June 3, 2011 Share Posted June 3, 2011 Cheers Quote Link to comment Share on other sites More sharing options...
dive_popo Posted June 3, 2011 Author Share Posted June 3, 2011 255 is really the narrowest size you should fit on a 10" rim going up to 285 being the widest. Wheel and Tyre sizes Here is a usefull guide along with a tyre calculator You should use the tyre calculator to get the correct profile to keep the rolling radius close to o/e, http://www.etyres.co.uk/tyre-size-calculator.htm Rim width---Min tyre width----Ideal tyre width-------Max tyre width 7.0 inches-----195 mm--------205 or 215 mm-----------225 mm 7.5 inches-----205 mm--------215 or 225 mm-----------235 mm 8.0 inches-----215 mm--------225 or 235 mm-----------245 mm 8.5 inches-----225 mm--------235 or 245 mm-----------255 mm 9,0 inches-----235 mm--------245 or 255 mm-----------265 mm 9.5 inches-----245 mm--------255 or 265 mm-----------275 mm 10.0 inches----255 mm--------265 or 275 mm-----------285 mm 10.5 inches----265 mm--------275 or 285 mm-----------295 mm 11.0 inches----275 mm--------285 or 295 mm-----------305 mm 11.5 inches----285 mm--------295 or 305 mm-----------315 mm 12.0 inches----295 mm--------305 or 315 mm-----------325 mm 12.5 inches----305 mm--------315 or 325 mm-----------335 mm Yeah, thanks dude !!! I was hoping the 285 and maximum 245 on the front to keep the good traction ? the calculator is sayin 285/30 on 18" wheels Isnt 30 too low ?? Quote Link to comment Share on other sites More sharing options...
