Air con pump change
bradleyh_15
Right my air con pump is whining like hell so I'm changing that and the auxiliary belt, I'm also doing the front crank seal at the same point but is there anything else I should/ could do while I'm doing these jobs?
I'm thinking water pump also?
Thanks in advance :)
If you are doing the crank seal I would recommend the oil pump also. Adds a LOT more work though.
Thanks Scott :) I'm taking some time off work to get some jobs done on the car so not to much of an issue adding to much more work load. I'll also be collaring my mechanic mate to pass me the spanners so fingers crossed 2 of us will be working on it at the same time! :D
