dr_jekyll Posted June 2, 2011 Share Posted June 2, 2011 i have built my new engine and fitted it to the car. just wondering what the full first start procedure is as at the moment im getting no joy making it start. so far i have; filled with cheap mineral oil. conected everything up; cranked with fuel relay out put fuel realy in crainked again and nothin tyred adding more timeing but its still not evan trying to fire. i dont want to keep cranking as im woried of damaging my new rings and at 1 point of it cranking it let out the loudest backfire ive ever heard so im not happy at the moment. any tips from youi guys that have run new engines would be great . thanks Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 2, 2011 Share Posted June 2, 2011 Kill the fuel, check for oil pressure, sparks at the right time, compression OK, cam timing OK. Once this is 100%, add fuel. Check injector dwell and go from there. Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 8, 2011 Author Share Posted June 8, 2011 cheers, so all sorted. engine is running smoth and quiet. so far i have ; let it idle for 5 mins and run it at 2000rpm for 20 mins 3 times then let it idle to temp then ran it at 2500 rpm for 10 mins all seems good no leaks ect. so what do i do now . i cant drive the car because its not mapped yet and its on far bigger injectors and a different turbo with lower compression than the current map is for. will it be ok to now drop the oil and put the good stuff in and send it for mapping or is it not ready to be taken that hard yet? Link to comment Share on other sites More sharing options...
pedrosixfour Posted June 8, 2011 Share Posted June 8, 2011 What plugs are in it Craig? According to the plug section in tech its recommended to map the engine on copper plugs of a suitable grade and gap. That way should something go wrong the plug gives up first and not your piston. Link to comment Share on other sites More sharing options...
mikeyb10supra Posted June 8, 2011 Share Posted June 8, 2011 cheers, so what do i do now . i cant drive the car because its not mapped yet and its on far bigger injectors and a different turbo with lower compression than the current map is for. ? You can off boost.......but thats no fun Link to comment Share on other sites More sharing options...
TLicense Posted June 8, 2011 Share Posted June 8, 2011 cheers, so all sorted. engine is running smoth and quiet. so far i have ; let it idle for 5 mins and run it at 2000rpm for 20 mins 3 times then let it idle to temp then ran it at 2500 rpm for 10 mins all seems good no leaks ect. so what do i do now . i cant drive the car because its not mapped yet and its on far bigger injectors and a different turbo with lower compression than the current map is for. will it be ok to now drop the oil and put the good stuff in and send it for mapping or is it not ready to be taken that hard yet? This may be of some interest to you.... http://www.mototuneusa.com/break_in_secrets.htm Link to comment Share on other sites More sharing options...
JustGav Posted June 8, 2011 Share Posted June 8, 2011 This may be of some interest to you.... http://www.mototuneusa.com/break_in_secrets.htm Now that is interesting, because I've heard this as well.... and tempted to research this option for my new smart engine when I finish it. Link to comment Share on other sites More sharing options...
TubbyTwo Posted June 8, 2011 Share Posted June 8, 2011 Thats interesting reading. Makes sense as well actually. Rebuilt my last MR2 engine and after about 50 miles of gentle driving I got bored and went for it. then never really bothered after that. Engine was faultless pulled very very hard and never really used that much oil. Link to comment Share on other sites More sharing options...
mellonman Posted June 8, 2011 Share Posted June 8, 2011 i like his thinking lead foot all the way lol Link to comment Share on other sites More sharing options...
johnny g Posted June 8, 2011 Share Posted June 8, 2011 Ryan had 1bar going through my fresh MR2 engine within 10 miles of driving The initial start of 2500rpm, temperature check, leakage check, etc, is good. Then after that, get it out and mapped! Low boost, then high boost. Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 8, 2011 Author Share Posted June 8, 2011 so basicly , stick the good oil in , give it to ryan and let him thrash it on the dyno ... sounds good , my kind of method Link to comment Share on other sites More sharing options...
Ricardod Posted June 8, 2011 Share Posted June 8, 2011 Good luck on the mapping , im pretty curious if the EMB can handle it. It propably will. Link to comment Share on other sites More sharing options...
