Stack wideband gauge st3401
supra matt
This is brand new no longer needed it's 52 mm , and has a full throttle hold function so you can check your Afr s after a wot run with out looking at the gauge while doing it , ,
£200 + p&p Just to add these are £240 new which this is ,
still have this here is what stack say about it .
Wide-band Air-Fuel (Lambda) Gauges
This is the ultimate tuning aid!
Dual digital and radial LED displays provide accurate real-time readout of either air/fuel ratio or lambda (user-selectable). A 0-4Volt analogue output can be connected to a data-logger or to an ECU to provide real-time closed-loop feedback for improved mapping. Supplied complete with wiring harness and includes Bosch sensor.
User-selectable Air/Fuel or Lambda real time display
Programmable Alarm warns of dangerous lean condition
Peak Recall of leanest value during last run
Suitable for all fuel types with AFR from 6:1 to 20:1 (not recommended for leaded fuel)
0-4 Volt Data Logger or ECU output
ST3401
ST3402
Manual also available in German, French & Italian.
Includes sensor as standard:
Wide-band Lambda O2 Sensor
Weight w/o Cable 120 g
Length 84 mm
Wrench Size 22 mm
Tightening Torque 40 … 60 Nm
Max. Vibration (stochastic peak level) 100 g
Exhaust Gas Temperature Range (Operating) 930 °C
Exhaust Gas Temperature Range (Maximum)
This sensor is NOT recommended for leaded fuel or two stroke engines.
Gauge comes complete with wiring harness and associated sensor. Replacement sensors available.
  • 3 weeks later...
  • 1 month later...
  • 2 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 2 months later...
