Jurgen-Jm-Imports Posted June 1, 2011 Share Posted June 1, 2011 i want to check a local customers car tomorrow is there a guide on how to check the AEM ecu.. i know people here have had issues with AEM.. so all i want to check is to see if the unit is faulty.. if the unit is OK then i can move onto other things to check with his car.. code 31 is for MAF but this car is JDM auto with big single turbo. thanks Link to comment Share on other sites More sharing options...
bignum Posted June 1, 2011 Share Posted June 1, 2011 I didnt think the aem stored fault codes, the only way to test the ecu is either fit it into another car(obviously loading the other cars map) or fitting a known good ecu into the suspect car. What problem are you getting anyway?. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted June 1, 2011 Author Share Posted June 1, 2011 I didnt think the aem stored fault codes, the only way to test the ecu is either fit it into another car(obviously loading the other cars map) or fitting a known good ecu into the suspect car. What problem are you getting anyway?. sorry the code is from the Diagnostics port ECU will still show faults this way ?,. the history that i know from car is that car has been starting some days and then some days it wont... runs pig rich and cold start is really bad on it way too rich(no idea who mapped it) been in uk a good few years now.. but now the car wont start.. we swapped the plugs just before we closed and still the same.. so i did ecu diagnostics and code 31 showed up. but i recall dangerous brian on here having an issue with a AEM ecu capicator coming loose so the car wont start and eventually failed. so i just wanting to check if the ecu was now faulty, car has single turbo and auto (all of my cars are 6 speed). will a normal auto tt ecu fire it up on 850cc injectors to eliminate ? Link to comment Share on other sites More sharing options...
michel lane Posted June 2, 2011 Share Posted June 2, 2011 sounds like the map is currupt upload another map. if you get stuck i have one that is used for an auto car with 850cc injector sand gt35r. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted June 2, 2011 Author Share Posted June 2, 2011 car runs now but floods on cold start, has 800cc inj and AEM FCI piggyback... i think new owner will need to change inj or get a better ecu to handle the 800s Link to comment Share on other sites More sharing options...
Ricardod Posted June 4, 2011 Share Posted June 4, 2011 jurgen, could you please specify how you solved the code 31 as my Na-T has the same error code and runs pig rich as well! i would greatly appreciate it. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted June 4, 2011 Author Share Posted June 4, 2011 hi mate, i spoke to ryan about this and we think the FIC is fautly... do you have FIC fitted ? or is just stock NA-T on stock ecu ? Link to comment Share on other sites More sharing options...
Ricardod Posted June 5, 2011 Share Posted June 5, 2011 (edited) Mine has emanage ultimate and stock ecu atm and it had the code 31 before i went NA-T. had a SAFC (gen1) fitted tho when it was Na-T (SAFC with those adjustable knobs) the SAFC was in the car when i bought it and by then it didnt have code 31. Not so long ago I did a datalog on cold startup and went for a drive. What i noticed was that the injector duration was 6,6ms on cold startup and during driving itwent to 12.5ms. also the map sensor sees positive pressure, is this possible? when lifting off the throttle the rpms go down to 400 and then jump to 900 and then down to 500 and then 900 slowly regaining a steady idle. i set the emanage jumpers on factory settings except for jumper 8 which i set to 12V instead of 5V for ignition ouput. My toughts on this would be the map sensor being faulty as i diagnosed the car and error code 31 came up (map sensor faulty or short in circuit). Maybe the lambda died aswell but i highly doubt it as its not even 1 year old. my setup: 2jzge-t emanage ultimate + 3bar map sensor (voltage clamped stock map @ 4.3V on every rpm) 3'' midpipe nur spec S backbox XTD stage 3 6puck ebay clutch One sided FMIC T61 (mark @ clubna-T's turbo) NGR Type S boV innovate LC1 wideband (took a crap on me, is dead as we speak...) 4runner dizzy cap adjustable cam gears OBX R 40mm WG NGK3330's Edited June 5, 2011 by Ricardod (see edit history) Link to comment Share on other sites More sharing options...
jase_93tt Posted June 5, 2011 Share Posted June 5, 2011 Hi Jurgen / Ricardod Im interested to see if you both managed to eliminate the error 31 code as mine has also started to display the 31 code, albeit Im using an Apexi Neo SAFC not AEM FIC. Ive tried swapping out the map sensor with a someone elses known - working item, but problem still persists. Car runs very rich, floods plugs, misfires like crazy, which is a shame as its ran like a beaut for passed 6 years of ownership, now this error shows up :/ TIA Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted June 5, 2011 Author Share Posted June 5, 2011 i think its difficult to diagnose each car, as they all seem to have same code and issues.. this particular car has no missfire , just floods the car instantly and hydrolocks.. possibly faulty injector or AEM FIC.. we are going to try AEM FIC and see what happens. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted June 5, 2011 Author Share Posted June 5, 2011 sounds like the map is currupt upload another map. if you get stuck i have one that is used for an auto car with 850cc injector sand gt35r. do you have a spare FIC to test on a car ? or can you send me the map to see if it might solve issue. Link to comment Share on other sites More sharing options...
jase_93tt Posted June 6, 2011 Share Posted June 6, 2011 OK, thanks Jurgen. Ive been doing a bit of googling, and found a thread on here from a few years back, which relates to a faulty TRL FCD or something inside the unit having a habit of becoming disconnected, thus throwing the error 31. Worth a peek I reckon. Link to comment Share on other sites More sharing options...
