Back firing on start up and spluttering idle.
hodge
Hey
The car has developed a backfire.
It all began when the water temp sensor became brittle and broke causing the car to overfuel horrendously. I drove the car maybe 1/2 mile max but not at anytime did the Defi temp gauge go above 92 degrees. I found the damaged connector and replaced it. Now on start up the car backfires before it starts and not splutters but sounds like a machine gun if I increase the revs and hold them with the pedal.
When Ryan was up last Wednesday we seemed to think there is an issue with my injectors. Maybe not the underlining problem but a contributing factor as there not responding as they should.
I've also checked the cam timing ETC and it's all fine.
Any thoughts on what could be wrong. I've already done a compression test and all cylinders were 175 psi.
Ryan mentioned a leak down test also but I just wanted some of your input into what could be causing this.
Thanks
John
I notice when mine goes very low on fuel my fuel pressure started to go allot lower and it sounded kind of rough too.
Mate is sounds horrendous. Even on cold start it backfires which is why I'm swaying towards an exhaust valve.
Tried the fuel mate? If not whats the afr gauge showing?
Other than that it could be sticky intake or exhaust valves? Might be the fuel pressure is too low? Possibly timing? Taken from wikipedia:
"When starting an engine, timing that is too advanced will fire the spark plug before the intake valve is closed. The flame front will travel back in to the intake manifold, igniting all of that air and fuel as well. The resulting explosion then travels out of the carburetor and air cleaner. A common air filter will allow the gases to escape, but will block the flame front"
Ignition and cam timing is both spot on, whilst Ryan was here we checked and double checked both of these. He also ssid the fuel pressure was fine. I really am in 2 minds wether to just pull the head off and have a look. Will only take me a couple of hours.
Michel Lane is kindly lending me a leakdown tester so I can confirm either way wether the head needs to come off or not. He has also offered to lend me parts from his white monster so I can narrow down what has actuallly gone wrong.
Thanks mate, I owe you a big favour.
have you tried the fuel ? its sounds crazy but it has worked in past
I've got the injectors and fuel rail out at the min mate. I've ordered a set of ID1000s but there going to take 2 weeks to arrive. Michel Lane said I can try his rail and injectors so that's the 1st port of call I think, as well as the leakdown test as that only takes a few mins and will put my mind at rest. I'll bung some more fuel in before I fire it up but I'm sure there is atleast a 1/4 of a tank in easy.
Hopefully it's a reasonably quick fix mate, let us know what is was when you find out though
Certainly will bud.
I would put a set of NEW plugs in it, after having spun it over perhaps 20 times with the fuel pump disconnected, all the old plugs out, and the throttle held wide open. I think the plugs have fouled due to the mad rich mixture before.
I was hoping you'd reply Chris. Do you think there could have Bern any damage inside the engine due to this.
