imran Posted May 31, 2011 Share Posted May 31, 2011 hi all my toyota supra turbo 6 speed maunal when you start it its fine when you rev it after 3000 rpm it goes mad and i cant stop it i have to turn the car off even when i do it from the engine its still the same can any help me. thanks Link to comment Share on other sites More sharing options...
SupraD06 Posted May 31, 2011 Share Posted May 31, 2011 Do you mean it keeps climbing up after 3000rpm or it sticks at that? Link to comment Share on other sites More sharing options...
imran Posted May 31, 2011 Author Share Posted May 31, 2011 when i rev it it fine up to 300 rpm after that it goes mad Link to comment Share on other sites More sharing options...
Gaz6002 Posted May 31, 2011 Share Posted May 31, 2011 You're going to have to try harder than 'goes mad' fella Link to comment Share on other sites More sharing options...
imran Posted May 31, 2011 Author Share Posted May 31, 2011 it keeps climbing Link to comment Share on other sites More sharing options...
imran Posted May 31, 2011 Author Share Posted May 31, 2011 when i start it up its fine, and when i give gas up to 3000 revs it redlines and i have to turn the car off to stop it Link to comment Share on other sites More sharing options...
SupraD06 Posted May 31, 2011 Share Posted May 31, 2011 Could be the throttle cable sticking? Your pulling the cable when pushing on the pedal, but when you release the pedal the throttle is stuck open Link to comment Share on other sites More sharing options...
imran Posted May 31, 2011 Author Share Posted May 31, 2011 even when i take the cable off the throttle body it still happens Link to comment Share on other sites More sharing options...
imran Posted May 31, 2011 Author Share Posted May 31, 2011 any one Link to comment Share on other sites More sharing options...
johnny g Posted May 31, 2011 Share Posted May 31, 2011 Give it time! Maybe pay a membership, and see if anyone's answered in that time Link to comment Share on other sites More sharing options...
Scott Posted May 31, 2011 Share Posted May 31, 2011 If you have taken the cable off the throttle body then it's the throttle body at fault mate. Snapped butterfly or something? Link to comment Share on other sites More sharing options...
Supra Gaz Posted May 31, 2011 Share Posted May 31, 2011 I think explaining the problem a bit more thoroughly would help? im going to go for the simplest explanation, is the throttle pedal trapped on your carpet? aka scaryprius syndrome Link to comment Share on other sites More sharing options...
imran Posted May 31, 2011 Author Share Posted May 31, 2011 yeah thanks il check maybe its that. Link to comment Share on other sites More sharing options...
imran Posted May 31, 2011 Author Share Posted May 31, 2011 no its not stuck on my carpet Link to comment Share on other sites More sharing options...
RobD Posted May 31, 2011 Share Posted May 31, 2011 yeah thanks il check maybe its that. no its not stuck on my carpet Take your intercooler pipe that's going onto the throttle body off and check inside the throttle body itself, see if there's anything noticeably wrong Link to comment Share on other sites More sharing options...
racestyle Posted May 31, 2011 Share Posted May 31, 2011 you had a dead battery ? or taken the battery off at any point , my clio did this , had to take the battery off for a few mins then it was fine Link to comment Share on other sites More sharing options...
downimpact Posted May 31, 2011 Share Posted May 31, 2011 I had an issue like this when a pipe was coming off to the intercooler, rev's kept building to 5000 and holding. Once the pipe came off it was fine just no boost. Don't know why not a mechanic, but once the pipes were refitted it fixed the problem. Link to comment Share on other sites More sharing options...
Robzki Posted May 31, 2011 Share Posted May 31, 2011 When I rev mine beyond 3-4000rpm it goes mental too, its the way with turbos I'm afraid Link to comment Share on other sites More sharing options...
imi Posted May 31, 2011 Share Posted May 31, 2011 wonder if he will sign up to share an update Link to comment Share on other sites More sharing options...
Havard Posted May 31, 2011 Share Posted May 31, 2011 Probably not, that costs money..!! Link to comment Share on other sites More sharing options...
Scooter Posted May 31, 2011 Share Posted May 31, 2011 is this a vvti car? Link to comment Share on other sites More sharing options...
imran Posted May 31, 2011 Author Share Posted May 31, 2011 rob d your the man done what you said i opened the pipe and a found a rubber pipe in there you the iam so happy. Link to comment Share on other sites More sharing options...
johnny g Posted May 31, 2011 Share Posted May 31, 2011 rob d your the man done what you said i opened the pipe and a found a rubber pipe in there you the iam so happy. See you next time you have a problem then I guess? Link to comment Share on other sites More sharing options...
Swampy442 Posted May 31, 2011 Share Posted May 31, 2011 See you next time you have a problem then I guess? Lol Id want to know where that rubber pipe came from and how it got into yout intake Link to comment Share on other sites More sharing options...
imran Posted May 31, 2011 Author Share Posted May 31, 2011 i can't belive it Link to comment Share on other sites More sharing options...
