supra tango Posted July 6, 2005 Share Posted July 6, 2005 hi to all I have a japanease import n/a supra, I would like to know should the milage show up in km or miles per hour I believe that it has had the speed limiter taken off but somebody told me that my milage screen should be reading in miles, can somebody please tell me what should be happening many thanks. lady supra owner Link to comment Share on other sites More sharing options...
Clarkey Posted July 6, 2005 Share Posted July 6, 2005 Should be reading in Miles. Talk to http://www.thor-racing.co.uk/DSC-00100007.asp .. they sell a box of tricks that converts the klicks into miles. Though, if it was trader you bought the car from ... I'd go back to them. Link to comment Share on other sites More sharing options...
supra tango Posted July 6, 2005 Author Share Posted July 6, 2005 hi thank you for the info i will be contacting that company now hopefully they can fit it as im not very good at cutting wires,once again much appricated help thanks Link to comment Share on other sites More sharing options...
Clarkey Posted July 6, 2005 Share Posted July 6, 2005 Matt Harwood is in Maidstone .. he'll be able to wire this up. Link to comment Share on other sites More sharing options...
merckx Posted July 6, 2005 Share Posted July 6, 2005 When the cars are imported the odometer reading will have to be reduced to read miles which is relatively easy with the digital display. The facelift supras have the conventional type of odometer in the speedo dial, ie wheels that rotate. Anyone know for certain how they turn back the reading to miles on these? I'm just wondering if it's always done and the mileage could be reading higher than it should. Link to comment Share on other sites More sharing options...
Steviekid Posted July 6, 2005 Share Posted July 6, 2005 The facelift supras have the conventional type of odometer in the speedo dial, ie wheels that rotate. Anyone know for certain how they turn back the reading to miles on these? Pretty sure for these odos they have to hook them up to a machine and basically wind them round until you pass zero then up to the correct figure again (which can take days!!). Link to comment Share on other sites More sharing options...
dangerous brain Posted July 6, 2005 Share Posted July 6, 2005 I'm sure most firms don't actually bother. my first car came with a really cheap and nasty speedo convertor and the odo was left in kilometers. When I did the thor conversion I left it in KM as I didn't want to confuse the cars history by changing it. As long as you can prove the car is still KM odo when you sell it and you do the servicings when they should be done then the odo reading won't be a problem. Link to comment Share on other sites More sharing options...
Fox Posted July 6, 2005 Share Posted July 6, 2005 Pretty sure for these odos they have to hook them up to a machine and basically wind them round until you pass zero then up to the correct figure again (which can take days!!). 9v battery drill Have never tryed this but i know a guy who did and he ended up buring the motors out of two drills before it went to the correct number! Link to comment Share on other sites More sharing options...
