neilthenut Posted May 30, 2011 Share Posted May 30, 2011 i'm after the top of a manual tunnel- (its rasided compaired with an auto) can anyone supply me with a part number so i can (try) to order 1 from toyota or recomend where i can get 1? thanks Quote Link to comment Share on other sites More sharing options...
Homer Posted May 30, 2011 Share Posted May 30, 2011 58261-14010 Try Steve Manley at Oxford Toyota hth Quote Link to comment Share on other sites More sharing options...
Nic Posted May 30, 2011 Share Posted May 30, 2011 58261-14010 Manual Transmission Cover. Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted May 31, 2011 Share Posted May 31, 2011 Make sure you cut the ns part off that mounts the handbrake in LHD, otherwise you will never line it up. Get ready to swear and use a jigsaw not and angle grinder to cut the trans tunnel, or you will melt all your wires like the mechanic did who fuc*ed mine up. Use gripfill and bolts to secure it in the tunnel. Also they have missed a part out to the conversion on the net. you need to make sure you short out the 2 biggest wires on the large plug going to the auto box after you have taken it out or the car wont start. hope this saves you the hassle I had, using a mechanic that knew it all. Quote Link to comment Share on other sites More sharing options...
neilthenut Posted May 31, 2011 Author Share Posted May 31, 2011 58261-14010 Try Steve Manley at Oxford Toyota hth thanks! 58261-14010 Manual Transmission Cover. thanks! Make sure you cut the ns part off that mounts the handbrake in LHD, otherwise you will never line it up. Get ready to swear and use a jigsaw not and angle grinder to cut the trans tunnel, or you will melt all your wires like the mechanic did who fuc*ed mine up. Use gripfill and bolts to secure it in the tunnel. Also they have missed a part out to the conversion on the net. you need to make sure you short out the 2 biggest wires on the large plug going to the auto box after you have taken it out or the car wont start. hope this saves you the hassle I had, using a mechanic that knew it all. not a big worry (dont know if you;ve seen my project tread) but thee is not a single wire in the car! and i'm converting a auto shell to take a complete manual set up from my donor car- so everything will me manual, but thanks-all help is much appricated how ever ya spell it!) Quote Link to comment Share on other sites More sharing options...
