bobapple Posted May 30, 2011 Share Posted May 30, 2011 Hey probably another silly question but , but am I ok to change the clips circled in the picture, for jubilee clips as those ones keep shredding my hands when polishing my pipe work . So if I can which are good ones as I have heard halfraud's are not that good to put it politely ( in none sweary terms ). Thanks Si Link to comment Share on other sites More sharing options...
pedrosixfour Posted May 30, 2011 Share Posted May 30, 2011 Jubilee is a brand name for a particular hose clip manufacturer. So your original question is a bit silly to be fair. And yes, it would be safe to change to hose clips, made by Jubilee, as I personally find them the best option (least likely to slip) for that particular type of hose clip. Link to comment Share on other sites More sharing options...
Mace Posted May 30, 2011 Share Posted May 30, 2011 Changed all my to 'Mikalor' brand clips off ebay same thing as jubilee though I suppose.. Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 30, 2011 Share Posted May 30, 2011 Those little spring clips are actually very effective (and not just at slicing your hands open). They impart a very even pressure on small OD hoses, something a Jubilee type clip isn't particularly good at in small sizes due to the larger percentage of the screw support area V banding arae. If they really bug you O clips put on neatly with the correct tool are very good, but have to be cut off to remove the pipe. http://www.jj-pneumatics.com/acatalog/Jubilee-O-Clips.html http://www.tools-supplies.co.uk/oetiker-o-clip-crimping-tool-3974-p.asp Link to comment Share on other sites More sharing options...
Scott Posted May 30, 2011 Share Posted May 30, 2011 Keep the clips, just rotate them away from where you are polishing Link to comment Share on other sites More sharing options...
bobapple Posted May 30, 2011 Author Share Posted May 30, 2011 Yea gonna leave them, Scott's right can just twist them. Thanks for the input gentlemen. Link to comment Share on other sites More sharing options...
