sweettom Posted May 30, 2011 Share Posted May 30, 2011 HI! I'ld like to buy this supra(93' TT Manual) and on this video shows that a little difficult starting. http://videa.hu/videok/jarmuvek/supra02-tdCCYOTD9daDOxf7 To your opinion what'll will be the problem with? nothing complicated? I know only that the exhaust is blowing under the turbo. Something opinion is from the chassis? Is it worth buying? There is here: http://videa.hu/videok/jarmuvek/supra03-mZx6qE167kjg8hVF Thank you for your help! Link to comment Share on other sites More sharing options...
Nic Posted May 30, 2011 Share Posted May 30, 2011 It's impossible to answer your questions from those videos and your description. Do you have a link to the sales advert? Link to comment Share on other sites More sharing options...
Branners Posted May 30, 2011 Share Posted May 30, 2011 didnt seem to have too much trouble starting, yes it didnt catch straight away, but it could just be spark plugs need changing. Link to comment Share on other sites More sharing options...
Morpheus Posted May 30, 2011 Share Posted May 30, 2011 Agreed but sounds like poor compression, possibly from loose or leaking sparkplug? Also check air filter, plug exhaust leaks and check ignition timing and then coolant for signs of BHG. Should be fine after a good service. Link to comment Share on other sites More sharing options...
