add heywood Posted May 29, 2011 Share Posted May 29, 2011 The brakes on the Supra are really bad at the min, the car is undrivable at the moment. When you drive if you place minimal pressure through the pedal they work, but when you start to press harder there is no more braking power to the car... I have tried the servo trick (pump brakes while car is off, keep pressure on pedal and start car, pedal drops to around halfway). Pedal does not drop to the floor, and pumping the brakes does not improve braking performance. Also car does not pull to either side when braking. The car has been stood pretty much since last September, an has only done about 3000 miles in the 3 years Ive had it. The brake fluid level is still to max. Any ideas? Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted May 29, 2011 Share Posted May 29, 2011 have you tried new fluid ? Quote Link to comment Share on other sites More sharing options...
Scott Posted May 29, 2011 Share Posted May 29, 2011 Siezed pistons. Quote Link to comment Share on other sites More sharing options...
add heywood Posted May 29, 2011 Author Share Posted May 29, 2011 have you tried new fluid ? Was going to book it in to get it done, but the brakes dont feel spongy at all. Siezed pistons. I was thinking the same, both fronts maybe sized and brake only working at the back... Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted May 29, 2011 Share Posted May 29, 2011 was just thinking if they have been braked hard over time and boiled over a little.. certainly worth changing every few years or so, if it was spongy it might have had air in system. but maybe check the pistons and try new fluid. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 29, 2011 Share Posted May 29, 2011 Maybe the master cylinder is biffed? Quote Link to comment Share on other sites More sharing options...
add heywood Posted May 29, 2011 Author Share Posted May 29, 2011 was just thinking if they have been braked hard over time and boiled over a little.. certainly worth changing every few years or so, if it was spongy it might have had air in system. but maybe check the pistons and try new fluid. Yeah I bled them, only a tiny bit of air... Ill take the discs off and check caliper piston for movement tomorrow Maybe the master cylinder is biffed? I was hoping people wouldnt say anything that sounded expensive lol Quote Link to comment Share on other sites More sharing options...
Homer Posted May 29, 2011 Share Posted May 29, 2011 Which brakes do you have? Are they new or old? I was hoping people wouldnt say anything that sounded expensive lol Compared to other possible problems, it's not expensive. There are refurb kits for these. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 29, 2011 Share Posted May 29, 2011 Actually, saying master cylinder, maybe not, if it was leaking past the seals the pedal would, more than likely, go to the floor. What brakes are they, J spec? Quote Link to comment Share on other sites More sharing options...
add heywood Posted May 29, 2011 Author Share Posted May 29, 2011 They are UK specs, on the car when I imported it 2008... Were fine before it came off the road last year... Car has done 64k Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 30, 2011 Share Posted May 30, 2011 From the test results you've posted I would say the best guess is that the caliper pistons are seized. It could be a weird master cylinder problem, but very unlikely that both front and rear circuits are affected together. Funnily enough I have 2 sets of stainless steel pistons left for sale, for UK calipers, to stop things like this occurring Quote Link to comment Share on other sites More sharing options...
