l33wgn Posted May 30, 2011 Share Posted May 30, 2011 this could just be my thoughts but this conversion is looking like 15k atm! why dont u just buy one done for 12k and call it a day? Link to comment Share on other sites More sharing options...
spiderpigcity Posted May 30, 2011 Share Posted May 30, 2011 this could just be my thoughts but this conversion is looking like 15k atm! why dont u just buy one done for 12k and call it a day? Its atleast that and thats if block is good to go and not other accidents or bad installs on the way. People always talk sh*t saying you can do it for 5k bla bla. To do it properly will cost you atleast 12k. I agree. fmc £1000 turbo £2000 manifold £1500 exhaust £600 injectors £800 Pumps £200 auto box £2500 ECU £2000 minimum Injector rail and fuel setup £1000 rear lsd £1000 big brakes £2500 wastegate £400 solenoid £50 Big Rad £300 Cooler £100 Tyres £1000 FPR £180 CAms £500 Timing belt and cam vernier pulleys £400 DLI £400 Map sensor £80 afr setup £200 various gages £400 tuning £500+ Fuel to tune £100 probably more but too tired now. Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 31, 2011 Share Posted May 31, 2011 Engine rebuild, asking a used high mileage engine from a scrapper to suddenly accept 600 BHP is too much to hope for. So rebore, pistons, rod crack and straightness test, new rod bolts, might as well use ARP ones, crank check and polish (if you are lucky, if not find another crank if the oil seal has worn a groove on its snout, or the journals are worn). A new oil pump, water pump, engine gasket set, valve reseat, lap and re shim, new stem seals, probably a set of cams, I'd put a new set of valve springs in it, new bearing shells, new core plugs, blah blah. Done properly it's easy to spend £20K + Link to comment Share on other sites More sharing options...
spiderpigcity Posted May 31, 2011 Share Posted May 31, 2011 Engine rebuild, asking a used high mileage engine from a scrapper to suddenly accept 600 BHP is too much to hope for. So rebore, pistons, rod crack and straightness test, new rod bolts, might as well use ARP ones, crank check and polish (if you are lucky, if not find another crank if the oil seal has worn a groove on its snout, or the journals are worn). A new oil pump, water pump, engine gasket set, valve reseat, lap and re shim, new stem seals, probably a set of cams, I'd put a new set of valve springs in it, new bearing shells, new core plugs, blah blah. Done properly it's easy to spend £20K + I agree, done it and have the sore Ars*ole to prove:) Link to comment Share on other sites More sharing options...
dodgydave13 Posted June 2, 2011 Author Share Posted June 2, 2011 thanks for all the help and advise i think buying one already done sounds a easyer way forward then i can improve on it sweet Link to comment Share on other sites More sharing options...
Guest wantthatone Posted June 2, 2011 Share Posted June 2, 2011 hey dave. hows it all coming along? Link to comment Share on other sites More sharing options...
