Advise_ Which multimeter to buy
bobapple
I need some help on which multimeter to buy, I need one which measures volts and ohms. It could also do with fine terminals which are on a lead as I may need to check things in some tricky places, don't want to spend a fortune as this is just to work out my trac cont issue.
Thanks
Si
Almost any digital multimeter will do for measuring voltage and resistance, you don't really need to spend more than £10 if you're hardly going to use it.
The ones that have an audible continuity feature are useful.
£7 delivered
The one I bought years ago for £5 still works pefectly, I've got a more expensive one too as I use it a lot.
