alex2jz Posted May 28, 2011 Share Posted May 28, 2011 (edited) Hi chaps, Think it's time i changed the coolant as it's never been done for quite some time now. Being my first time doing this, i am a bit nervous, knowing i can really mess things up Looking up at the numerous " How to change your coolant" tutorials over the internet I've sorted the steps in my head : 1. Drain the coolant from the radiator and expansion tank 2. Fill and drain the radiator with water until the water comes out clean ( i don't have the tools to flush the system) 3. Fill the radiator with the 50/50 mix of coolant ( i've got the Toyota red stuff). Fill the expansion tank hallfway. 4. Start your engine with the radiator cap off and let it run for approximately 10 minutes. Then turn on your heater, and turn it up to hot. This will circulate the coolant and allow any trapped air along with it to dissipate And that would be all. Please tell if there's something i'm not doing or doing it wrong. Cheers Alex Edited May 28, 2011 by alex2jz (see edit history) Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 28, 2011 Share Posted May 28, 2011 (edited) Drain and flush out system, empty system Refill with coolant. Run the engine till it gets to normal running temp and the stat has opened, set heater to max hot, keep the engine running with the rad cap off letting out any trapped air, raise the revs a little to help do this, check the heater is blowing out HOT air refit rad cap. Check temp stays at normal and check the next day when cold, rad level and expansion tank level Don't water down the red stuff coolant, its pre mixed Edited May 28, 2011 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
alex2jz Posted May 28, 2011 Author Share Posted May 28, 2011 (edited) Drain and flush out system, empty system Refill with coolant. Run the engine till it gets to normal running temp and the stat has opened, set heater to max hot, keep the engine running with the rad cap off letting out any trapped air, raise the revs a little to help do this, check the heater is blowing out HOT air refit rad cap. Check temp stays at normal and check the next day when cold, rad level and expansion tank level Don't water down the red stuff coolant, its pre mixed Thanks mate ! By draining and flushing the radiator only, will i get enough\all of the old coolant out of the system ? Also, what's bugging me is that the coolant i have in my expansion tank at the moment is very odd, it has no color, it looks like plain water Is this normal ? Edited May 28, 2011 by alex2jz (see edit history) Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 28, 2011 Share Posted May 28, 2011 (edited) You'll still have coolant or water in the block and heater. Why not run the car and flush through the system with water with the engine running then drain that off, you wont be able to get it all out. There is a drain bolt on the side of the block though which you undo, it has a pipe sticking out underneath it I wouldnt worry about whats in the expansion tank now if your changing it but it definitely shouldnt be clear or just water. Edited May 28, 2011 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
alex2jz Posted June 18, 2011 Author Share Posted June 18, 2011 You'll still have coolant or water in the block and heater. Why not run the car and flush through the system with water with the engine running then drain that off, you wont be able to get it all out. There is a drain bolt on the side of the block though which you undo, it has a pipe sticking out underneath it I wouldnt worry about whats in the expansion tank now if your changing it but it definitely shouldnt be clear or just water. Problem is i don't have access to a garden hose. I'm thinking of draining the radiator and drain what i can by opening the drain bolt on the side of the block, BTW is that on the passenger or driver side ? Only thing resembling a drain bolt i can find on the drivers side. Then fill the radiator with water run the engine, drain all the contents and refill with coolant. Also, does this look like Toyota Red coolant ? Looks kind of pink to me. Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 18, 2011 Share Posted June 18, 2011 The system holds approx 8 litres so if you just drain out whats in it then refill with water from a watering can then run and drain through and repeat it should be fine. I think the block drain bolt is on the turbo side towards the bulkhead but is quite tricky to get at. Cant tell the colour but just empty it and wash it out with clean water and refill with your new coolant Quote Link to comment Share on other sites More sharing options...
alex2jz Posted June 18, 2011 Author Share Posted June 18, 2011 The system holds approx 8 litres so if you just drain out whats in it then refill with water from a watering can then run and drain through and repeat it should be fine. I think the block drain bolt is on the turbo side towards the bulkhead but is quite tricky to get at. Cant tell the colour but just empty it and wash it out with clean water and refill with your new coolant Cheers mate ! Quote Link to comment Share on other sites More sharing options...
alex2jz Posted July 3, 2011 Author Share Posted July 3, 2011 (edited) EDIT : Wrong thread lol Edited July 3, 2011 by alex2jz (see edit history) Quote Link to comment Share on other sites More sharing options...
