Noz Posted May 28, 2011 Share Posted May 28, 2011 Going to change my plugs sometime this weekend, any bits of advice before I start removing bolts from the intake manifold? Link to comment Share on other sites More sharing options...
David P Posted May 28, 2011 Share Posted May 28, 2011 Remember to 'nip up' the rocker cover bolts whilst you can get at them. Link to comment Share on other sites More sharing options...
Konrad Posted May 28, 2011 Share Posted May 28, 2011 No need to remove intake manifold, just remove Throttle body (6 screws size 12) remove long pins with E8 star socket and get to spark plug no 3 and 4 using universal joint and short spark plug socket. Link to comment Share on other sites More sharing options...
barneybrendan Posted May 28, 2011 Share Posted May 28, 2011 no need to actually remove anything apart from the plastic covers the throttle body will pull forward enough to get at the plugs once the bolts and nuts have been undone. Link to comment Share on other sites More sharing options...
Noz Posted May 29, 2011 Author Share Posted May 29, 2011 awesome guys thanks Link to comment Share on other sites More sharing options...
Mr Cull Posted September 25, 2011 Share Posted September 25, 2011 no need to actually remove anything apart from the plastic covers the throttle body will pull forward enough to get at the plugs once the bolts and nuts have been undone. See post 37 in http://www.mkivsupra.net/vbb/showthread.php?4262-S-Plugs/page3 for annotated pic. Link to comment Share on other sites More sharing options...
Nic Posted September 26, 2011 Share Posted September 26, 2011 http://mkiv.com/techarticles/spark_plugs/na/index.html Link to comment Share on other sites More sharing options...
