Guigsy Posted May 27, 2011 Share Posted May 27, 2011 Ok so I think I might bin my hks bov to see what it sounds like without it. The car is uk spec bpu. With the bov in stock location. What's the best way to close the ends of the pipes etc? Link to comment Share on other sites More sharing options...
marc_p Posted May 27, 2011 Share Posted May 27, 2011 I'm glad you posted this as I'm wanting to do the same Link to comment Share on other sites More sharing options...
Scott Posted May 27, 2011 Share Posted May 27, 2011 19mm stopper at both ends. You should have one on there already, to block off where the recirc end of the stock valve went..... unless you used the recirc pipe on the HKS? http://www.mkivsuprastar.com/Forsale.htm#Bung Link to comment Share on other sites More sharing options...
SupraDan24 Posted May 27, 2011 Share Posted May 27, 2011 What does it sound like without it, is it that "chatter" noise? Link to comment Share on other sites More sharing options...
scotty71 Posted May 27, 2011 Share Posted May 27, 2011 some people steal grandads walking stick rubber end I sh!t you not Link to comment Share on other sites More sharing options...
Scott Posted May 27, 2011 Share Posted May 27, 2011 some people steal grandads walking stick rubber end I sh!t you not Very common. I get the "chatter" noise just now at low boost Link to comment Share on other sites More sharing options...
SupraDan24 Posted May 27, 2011 Share Posted May 27, 2011 Isnt that chatter noise the sound of the air going the wrong way through the turbo tho? I'm sure i read that somewhere, and that it was detramental to the turbo? Could be wrong....sounds cool thou Link to comment Share on other sites More sharing options...
Scott Posted May 27, 2011 Share Posted May 27, 2011 Isnt that chatter noise the sound of the air going the wrong way through the turbo tho? I'm sure i read that somewhere, and that it was detramental to the turbo? Could be wrong....sounds cool thou It's the turbo stalling, I wouldn't worry to much about it to be honest. Link to comment Share on other sites More sharing options...
SupraDan24 Posted May 27, 2011 Share Posted May 27, 2011 If i wanted to worry i'd get Anti Lag Now THAT sounds cool lol. Link to comment Share on other sites More sharing options...
Guigsy Posted May 27, 2011 Author Share Posted May 27, 2011 (edited) It's not recerculating ATM and that part is blocked with a clamp and a rubber dome I assume there is something under it. But I'm sure there are a few bits of hose to remove I'll man the spanners tomorrow maybe. Edited May 27, 2011 by Guigsy (see edit history) Link to comment Share on other sites More sharing options...
Jellybean Posted May 27, 2011 Share Posted May 27, 2011 http://cgi.ebay.ie/Rubber-Walking-Stick-Cane-Ferrules-Pck-4-Pack-Any-Size-/280500644564?pt=LH_DefaultDomain_3&var=&hash=item870aece294 HKS http://whifbitzperformancetuning.co.uk/toyota-supra-supra-cooling-parts-radiatorshosesfans-caps-hks-p-1873.html Link to comment Share on other sites More sharing options...
Paul Whiffin Posted May 27, 2011 Share Posted May 27, 2011 Ok so I think I might bin my hks bov to see what it sounds like without it. The car is uk spec bpu. With the bov in stock location. What's the best way to close the ends of the pipes etc? I keep the HKS rubber bungs in stock if needed, perfect for the job. Link to comment Share on other sites More sharing options...
Jellybean Posted May 27, 2011 Share Posted May 27, 2011 I keep the HKS rubber bungs in stock if needed, perfect for the job. Linky HKS http://whifbitzperformancetuning.co.uk/toyota-supra-supra-cooling-parts-radiatorshosesfans-caps-hks-p-1873.html Link to comment Share on other sites More sharing options...
Robzki Posted May 28, 2011 Share Posted May 28, 2011 Linky HKS http://whifbitzperformancetuning.co.uk/toyota-supra-supra-cooling-parts-radiatorshosesfans-caps-hks-p-1873.html Been looking to get something like that for ages I have walking stick rubbers atm If anyone is looking to ditch their bov I'm looking to buy one at the moment too Link to comment Share on other sites More sharing options...
Lude Posted May 28, 2011 Share Posted May 28, 2011 i took the rubber hose off mine as it split when i tried putting a bung init. so i then put a walking stick rubber over it at the boost end. at the other end/ the vacuum i put a 19mm wheel nut in Link to comment Share on other sites More sharing options...
ManwithSupra Posted May 28, 2011 Share Posted May 28, 2011 Is there anything to gain performance wise doing this? Or is it just the chatter sound? Link to comment Share on other sites More sharing options...
Lude Posted May 28, 2011 Share Posted May 28, 2011 chatter sound. tbh tho, mine did the chatter noise with or without the stock recirc in. just an Apexi intake & intercooler Link to comment Share on other sites More sharing options...
marc_p Posted June 22, 2011 Share Posted June 22, 2011 Can I just bump this as I'm going to do this with mine, I can block the 2 main pipes but what do I do with the 3rd pipe that goes to the top of the stock bov? Link to comment Share on other sites More sharing options...
