Air con clicks in and out every few seconds? Ice cold air still
Aero-M
I have just brought a transit 260 swb, it is a 55 plate with air-con. The air con is very cold but the bit on the end of the compressor clicks in and out every few seconds constantly? Is this normal as I don't remember the supra doing it, the man I brought it from had another 54 reg transit and that did exactly the same.
Does it do it all the time or when its stabilized at a set temp?
Seems to do it all the time, I can't hear it when driving but after the test drive it was doing it and I haven't used it since I got home as the ignition has broken.
I would say if it was stabilized its just the ECU controlling the temp in the cabin, apart from that I cant help, sorry
Ok thank you, I will put the new barrel in tomorrow and see what happens when I turn the air con on hopefully it will be because I had driven it and it was stabilised as you said.
