bobapple Posted May 27, 2011 Share Posted May 27, 2011 (edited) Where would I find this , when it says solenoid relay is it referring to the the ABS fuses, I get a code 22 and I think it is making my slip cont off light flash constantly. Thanks Si Edited May 28, 2011 by bobapple (see edit history) Quote Link to comment Share on other sites More sharing options...
bobapple Posted May 27, 2011 Author Share Posted May 27, 2011 This is what the manual says for code 22. 22 Conditions (1) through (3) continue for 0.05 sec. or more: (1) ABS solenoid relay terminal (SR) voltage: Below 1.5V (2) Voltage of ABS ECU terminal AST: Battery positive voltage (3) When power transistor of ECU is ON, voltage of terminal SFL is 0 V or battery positive voltage. L ABS actuator L Open or short in SFLH or SFLR circuit Quote Link to comment Share on other sites More sharing options...
Durandal Posted May 27, 2011 Share Posted May 27, 2011 the ABS solenoid relay is in the little black box on the left side under the bonnet I believe. There are 4 relays there, some are for the TRAC. They are green and yellow. Quote Link to comment Share on other sites More sharing options...
bobapple Posted May 27, 2011 Author Share Posted May 27, 2011 (edited) If I were to pull the ABS one would, the ABS warning light come on ? As I just had a quick look and the trac and abs seem to be the same so if I swapped them round I would know ones buggered. Thanks Si Just went and tried this and yes it does stay on so swapped the relays round and the abs went off , guessing it's to do with the wiring it's self between relay and ECU. Any auto electrician magicians near Bolton way ?? Again Thanks Si Edited May 27, 2011 by bobapple (see edit history) Quote Link to comment Share on other sites More sharing options...
bobapple Posted May 27, 2011 Author Share Posted May 27, 2011 http://www.turbosupras.com/pdfs/JZA80%20TSRM/DI.pdf Info here for any wiring geniuses, starts around page 542. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 27, 2011 Share Posted May 27, 2011 (edited) I find people who work on installing ecus and data logging dashes are pretty good at wiring checking. So how about seeing if Ryan is up for a fiddle with it? At the end of the day checking the wiring is just down to agility, patience, a logical approach, and good eyesight. I fail on most counts.... Howard would put the car on the brake tester and put one of his `scopes on the ABS wires under the bonnet, and confirm clean signals from the front ABS sensors, he could do the same in the boot. That won't tell you if the signals reach the ABS control unit under the radio. If you were to get the connector accessible, yet leave the car drivable, I would have a go at reading the signals on the road, with my scope, if we can find a mutually convenient time. I think you need to be sure all 4 ABS wheel speed sensors are sending clean signals to the ABS control unit first, then go from there. Have you got all the bumf on checking the ABS? I have the OE manuals, but they are for UK / US cars which have different, more sophisticated ABS control. Edited May 27, 2011 by Chris Wilson (see edit history) Quote Link to comment Share on other sites More sharing options...
bobapple Posted May 27, 2011 Author Share Posted May 27, 2011 (edited) Thanks mate, I think that articles is of the US forum to be honest in that Pdf it says to check connector/ harness, from what I could tell the relay only goes to the ECU as that was at the top of a pyramid table showing it going relay to ecu to actuator. So the relay either isn't sending out power or just not receiving it at all I think. But the relay is working as I swapped the abs and trac one round. I just read some more and found this, and now even more confused , . Edited May 27, 2011 by bobapple (see edit history) Quote Link to comment Share on other sites More sharing options...
bobapple Posted May 28, 2011 Author Share Posted May 28, 2011 Does anyone know if the trac relay sends or receives power from the throttle position motor? Thanks Si Quote Link to comment Share on other sites More sharing options...
bobapple Posted May 28, 2011 Author Share Posted May 28, 2011 Just took the bottom of the relay box off checked wires and cleaned with spray, but to no avail, it has several wires going to that relay, if only I knew which one was which more reading I think unless someone can shed some light . Quote Link to comment Share on other sites More sharing options...
bobapple Posted May 29, 2011 Author Share Posted May 29, 2011 Hey everyone, does anyone know if you should be able to move the first throttle butterfly the one thats worked by the motor with the motor still attached ? As just popped my inlet pipe off and it wouldn't budge on mine. Thanks Si Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 29, 2011 Share Posted May 29, 2011 I would need to have a look at one, will try tomorrow, but I think you need to take the TRAC motor off (4 screws?). If it goes into no start mode you could pull the motor and get someone to manually hold the TRAC butterfly open, and see if it effects an immediate cure. It's problems like this that make my GTS-t such a joy. No ABS, no traction control, no fly by wire, no air con, minimal electrics, and access to current wiring diagrams and manuals in English that match the car exactly, rather than being for a US spec, like the Supra. Rip the damned thing off Quote Link to comment Share on other sites More sharing options...
bobapple Posted May 30, 2011 Author Share Posted May 30, 2011 Little vid I just found quite funny (98 is looking dated )but good info on the Supra trac system. Quote Link to comment Share on other sites More sharing options...
