Morpheus Posted May 27, 2011 Share Posted May 27, 2011 Good post +1 Link to comment Share on other sites More sharing options...
Josh Posted May 27, 2011 Author Share Posted May 27, 2011 There you go. Thanks for the help The orange circle is a rubber cap over the head of a bolt/screw that says "do no adjust". Link to comment Share on other sites More sharing options...
Morpheus Posted May 27, 2011 Share Posted May 27, 2011 +1 Dumbass! Link to comment Share on other sites More sharing options...
Morpheus Posted May 27, 2011 Share Posted May 27, 2011 Dumbass! +1 Link to comment Share on other sites More sharing options...
Morpheus Posted May 27, 2011 Share Posted May 27, 2011 There you go. Thanks for the help The orange circle is a rubber cap over the head of a bolt/screw that says "do no adjust". http://i1223.photobucket.com/albums/dd508/Josh3Sheets/002-3.jpg Don't adjust that one Josh. Link to comment Share on other sites More sharing options...
Scott Posted May 27, 2011 Share Posted May 27, 2011 There you go. Thanks for the help The orange circle is a rubber cap over the head of a bolt/screw that says "do no adjust". http://i1223.photobucket.com/albums/dd508/Josh3Sheets/002-3.jpg What's the black part? Link to comment Share on other sites More sharing options...
SPG Posted May 27, 2011 Share Posted May 27, 2011 Why Link to comment Share on other sites More sharing options...
merckx Posted May 27, 2011 Share Posted May 27, 2011 I suggest you pay a bit more and buy a long reach trolley jack, otherwise, if you jack up under the rear diff casing, a stock one will have the handle under the car. Long reach, low height ones are a Godsend. Machine Mart do some half decent ones for home usage. This one looks OK, longish reach, reasonably low height. Very good advice- long reach and low is very important for the Supra. It wouldn't even cross my mind to get anything more than a 2 tonne jack, they would lift up much more than that in practice as they design them that way using factors of safety (FoS) etc. Link to comment Share on other sites More sharing options...
Morpheus Posted May 27, 2011 Share Posted May 27, 2011 Why Because it says, "Do not adjust". Link to comment Share on other sites More sharing options...
SPG Posted May 27, 2011 Share Posted May 27, 2011 Because it says, "Do not adjust". oh right Link to comment Share on other sites More sharing options...
Scott Posted May 27, 2011 Share Posted May 27, 2011 Very good advice- long reach and low is very important for the Supra. It wouldn't even cross my mind to get anything more than a 2 tonne jack, they would lift up much more than that in practice as they design them that way using factors of safety (FoS) etc. Not to mention relief valves to stop them from being overloaded. No danger in a reasonable jack IMO. It's the cheapo £10 that the issues lie with. I think Josh has made the wrong choice to be honest, we could only advise him though... not do the shopping for him Link to comment Share on other sites More sharing options...
SPG Posted May 27, 2011 Share Posted May 27, 2011 Just outta interest, what are the standard scissor style jacks rated too Link to comment Share on other sites More sharing options...
Scott Posted May 27, 2011 Share Posted May 27, 2011 Just outta interest, what are the standard scissor style jacks rated too The corner of a supra. Probably 0.75 ton or something like that. Although they will be stress tested far higher. Link to comment Share on other sites More sharing options...
Josh Posted May 27, 2011 Author Share Posted May 27, 2011 Not to mention relief valves to stop them from being overloaded. No danger in a reasonable jack IMO. It's the cheapo £10 that the issues lie with. I think Josh has made the wrong choice to be honest, we could only advise him though... not do the shopping for him It'll fit under my stock-bodied Supra so it'll be ok. If not then I can always take it back Just outta interest, what are the standard scissor style jacks rated too 950kg or so. Link to comment Share on other sites More sharing options...
Josh Posted May 27, 2011 Author Share Posted May 27, 2011 What's the black part? http://www.mkivsupra.net/vbb/attachment.php?attachmentid=133428&stc=1&d=1306531684 It's just a hole, poked it with a pen and it feels rubbery inside. Link to comment Share on other sites More sharing options...
Scott Posted May 27, 2011 Share Posted May 27, 2011 It's just a hole, poked it with a pen and it feels rubbery inside. That'll be your fill hole bud. Is it not a screwdriver centre? Where you could unscrew it with a narrow plain screwdriver? Link to comment Share on other sites More sharing options...
Marty Posted May 27, 2011 Share Posted May 27, 2011 the black bit poking out under the handle, slightly to the right if you're looking at it from the back, use a spanner, twist it all the way in to jack it up, then twist back out (anticlockwise) to drop it back down Link to comment Share on other sites More sharing options...
Josh Posted May 27, 2011 Author Share Posted May 27, 2011 That'll be your fill hole bud. Is it not a screwdriver centre? Where you could unscrew it with a narrow plain screwdriver? It just appears to be a blocked off hole. I'd shone an LED into it and it is just a blocked hole. Cheers man, I'll leave you be and just work it out myself . Cheers man! the black poking out bit under the handle, slightly to the right if you're looking at it from the back, use a spanner, twist it all the way in to jack it up, then twist back out (anticlockwise) to drop it back down I got that bit, just the instructions aren't clear at all! Link to comment Share on other sites More sharing options...
Morpheus Posted May 27, 2011 Share Posted May 27, 2011 It's just a hole, poked it with a pen and it feels rubbery inside. Every hole's a goal! Link to comment Share on other sites More sharing options...
Marty Posted May 27, 2011 Share Posted May 27, 2011 I got that bit, just the instructions aren't clear at all! Ah right, thought that was what you were struggling with. Link to comment Share on other sites More sharing options...
Josh Posted May 27, 2011 Author Share Posted May 27, 2011 Ah right, thought that was what you were struggling with. Nah, trying to release the air. The instructions tell you what to do but don't show where anything is at all. I guess that's what you get for buying a "cheaper" product Link to comment Share on other sites More sharing options...
Scott Posted May 27, 2011 Share Posted May 27, 2011 It just appears to be a blocked off hole. I'd shone an LED into it and it is just a blocked hole. Cheers man, I'll leave you be and just work it out myself . Cheers man! I got that bit, just the instructions aren't clear at all! It's still the fill hole bud, whether you leave it or not that's what it is. It will be a rubber plug, pull it out to fill up, bleed, etc. I can't wait to read threads when you are actually working on the car Link to comment Share on other sites More sharing options...
Josh Posted May 27, 2011 Author Share Posted May 27, 2011 It's still the fill hole bud, whether you leave it or not that's what it is. It will be a rubber plug, pull it out to fill up, bleed, etc. I can't wait to read threads when you are actually working on the car You're a smart bugger. PM me your address and I'm mail you a kiss It is a plug. Bloody me! Nice one mate. I'm ok when working on the car as there are loads of threads (using the search ) explaining how to do stuff, it's just crap like this. I'm better with a hammer and a spanner than an intricate, sh!tty instructioned thing like this! Link to comment Share on other sites More sharing options...
Scott Posted May 27, 2011 Share Posted May 27, 2011 You're a smart bugger. PM me your address and I'm mail you a kiss It is a plug. Bloody me! Nice one mate. I'm ok when working on the car as there are loads of threads (using the search ) explaining how to do stuff, it's just crap like this. I'm better with a hammer and a spanner than an intricate, sh!tty instructioned thing like this! Not the man to call when the MFI flat-pack arrives then? Link to comment Share on other sites More sharing options...
Josh Posted May 27, 2011 Author Share Posted May 27, 2011 Not the man to call when the MFI flat-pack arrives then? Yeah, I was just trying to make it sound better than saying "I'm a goon and wasn't looking at it properly Link to comment Share on other sites More sharing options...
