Coilpack Question
SPG
Hi everyone,
i am finally getting my car back on the road after a long spell Sorn'd. I managed to change my Spark plugs as i thought that this was my problem as the engine is Missfiring on cylinder 6. Changed these all over to some Iridium plugs and turned her over and still the same problem.
Sent it into the garage for a more thorough look and the mechanic has found that the coilpack on cylinder 6 is not working. I replaced all the coilpack clips last week whilst i changed the spark plugs, so that is out of the window too.
Should i just Bite the bullet and replace the standard CP with the SuperSpark ones that LeeP sells? Or should i just replace the one?
Hi Guys, the Sup went to the garage and they did all the testing, including the cylinder swap and the same thing happened. Definitely goosed but are the Mr T coilpacks around the same price as these Super Spark variants. Also am I best just swapping all 6 for new ones
If you want just 1 bud i have a spare mint 1, least it will get you by then you will have a set of 6 you can sell if you buy the uprated ones.
TBH id just change the broken 1 as they dont normally stop working unless they crack.
I have 4 so can sell you 2 so you have a spare.
