ZippyTT Posted May 26, 2011 Share Posted May 26, 2011 I have found a set of Tein S-Tech lowering springs on E-Bay. The add says that they lower 35mm front and 42mm rear! As the car rides higher on the front as standard is this correct or is it the other way around (35mm rear and 42mm front)?? Can anybody help? Cheers Zippy Quote Link to comment Share on other sites More sharing options...
Nic Posted May 26, 2011 Share Posted May 26, 2011 You should find out which S-Tech springs they are, as there are differences between the Tein USA and the Tein Japan springs Tein USA Universal Front 28mm Rear 25mm Tein Japan 2JZ-GTE Front 36mm Rear 42mm 2JZ-GE Front 32mm Rear 20mm Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted May 28, 2011 Share Posted May 28, 2011 36 front 42 rear i have them have a look in my garage they ride like stock slight improvment in handling but car looks great lowered Quote Link to comment Share on other sites More sharing options...
